Q: Magic Sinewave short sequence
Discussion in 'Electronic Design' started by Henry Kiefer, Mar 31, 2007.
  1. Henry Kiefer
    Henry Kiefer Guest
    Hi all -
    Is there any useful resource for exploring Magic Sinewaves other than Don's site? I read his pages but lost in the infos. His online
    calculators deal with selfmade syntax I don't understand.
    He doesn't answer to my email asking for simple help.
    I need a short bit sequence not more than say 300 bits long. Lower harmonics are much more important to me. Behind say the 9th I
    don't care.
    The sequence must be a multiple of eight to run a simple controller reloaded shift register.
    I prefer a short sequence.
    Any help?
    regards -
    Henry
  2. Henry Kiefer
    Henry Kiefer Guest
    It is a general kind of harmonic suppression.
    I worked a little on and the simulation of the following sequence shows approx. 15dB harmonics suppression:
    one quadrant is: 6-3-5-2-11
    whole length is: 108
    next binary length is: 216
    So there are two sine/cosine periods in one 216 sequence.
    Surely there are much better ones. Just I don't know exactly how to calculate them.
    Just to drive the discussion on ;-)
    regards -
    Henry
  3. Guest
    Stupid suggestion:
    How about brute force? Use a Genetic Algorithm to guess a bit sequence, express
    it's fitness in the product of correlation to the desired output and the RMS of
    the lower harmonics calculated as an FFT of the waveform.
    To me, it does not matter if the computer have to run for a few days - this
    gives time for fun things.
  4. Henry Kiefer
    Henry Kiefer Guest
    FFT is the way, surely.
    Working in the garden and let the pc done the work...
    Stupid answer:
    I don't the big programmer to write that prog.
    Second stupid answer:
    Somewhere is surely a list of useful sequences.
    You can find pi, e or similar values already done to 300 digits.
    Or lists of the cross-correlation properties of CDMA sequences. Gold code, Baker, etc.
    But where for Magic Sinewaves? Just the wrong name for it?
    regards -
    Henry
    www.ehydra.dyndns.info
    | > don't care.
    | Stupid suggestion:
  5. Henry Kiefer
    Henry Kiefer Guest
    | What you want is papers on the subject of "harmonic elimination".
    | Have a look at:
    | http://www.ece.utk.edu/~tolbert/publications/apec_2003_complete.pdf
    | He refers to the classic older reference:
    | "Generalized Harmonic Elimination and Voltage Control in Thyristor
    | Inverters: Part 1--Harmonic Elimination", H. S. Patel and R. G. Hoft, IEEE
    | Transactions on Industrial Applications, Vol. IE-9, pp. 310-317, May/June
    | 1973.
    | Also look at all the rest of his material on:
    | http://www.ece.utk.edu/~tolbert/pubs.htm
    Interesting. I read it all but understood not very much ;-(
    There are at least two main differences:
    - He doesn't take care of the 3rd overtone. But this is a most important one for me.
    - And he is using multilevels drive. My system is bipolar only. I cannot see an easy way to convert between the different systems.
    So it is interesting but not useful.
    Thanks again!
    - Henry
  6. The Phantom
    The Phantom Guest
    Have a look at:
    1973.
  7. The Phantom
    The Phantom Guest
    Did you look at the first paper:
    He specifically discusses bipolar modulation. The method is certainly
    capable of eliminating the 3rd harmonic; you will have to work out the
    details yourself.
    The paper:
    "Multiple Sets of Solutions for Harmonic Elimination PWM Bipolar Waveforms:
    Analysis and Experimental Verification", Agelidis, Balouktsis, and Cossar,
    IEEE Transactions on Power Electronics, March 2006.
    deals only with bipolar waveforms.
  8. Fred Bartoli
    Fred Bartoli Guest
    Henry Kiefer a écrit :
    Here are 10000s of them for pi :)
    Want e too?
    3.1415926535897932384626433832795028841971693993751058209749445923078164062862\
    089986280348253421170679821480865132823066470938446095505822317253594081284811\
    174502841027019385211055596446229489549303819644288109756659334461284756482337\
    867831652712019091456485669234603486104543266482133936072602491412737245870066\
    063155881748815209209628292540917153643678925903600113305305488204665213841469\
    519415116094330572703657595919530921861173819326117931051185480744623799627495\
    673518857527248912279381830119491298336733624406566430860213949463952247371907\
    021798609437027705392171762931767523846748184676694051320005681271452635608277\
    857713427577896091736371787214684409012249534301465495853710507922796892589235\
    420199561121290219608640344181598136297747713099605187072113499999983729780499\
    510597317328160963185950244594553469083026425223082533446850352619311881710100\
    031378387528865875332083814206171776691473035982534904287554687311595628638823\
    537875937519577818577805321712268066130019278766111959092164201989380952572010\
    654858632788659361533818279682303019520353018529689957736225994138912497217752\
    834791315155748572424541506959508295331168617278558890750983817546374649393192\
    550604009277016711390098488240128583616035637076601047101819429555961989467678\
    374494482553797747268471040475346462080466842590694912933136770289891521047521\
    620569660240580381501935112533824300355876402474964732639141992726042699227967\
    823547816360093417216412199245863150302861829745557067498385054945885869269956\
    909272107975093029553211653449872027559602364806654991198818347977535663698074\
    265425278625518184175746728909777727938000816470600161452491921732172147723501\
    414419735685481613611573525521334757418494684385233239073941433345477624168625\
    189835694855620992192221842725502542568876717904946016534668049886272327917860\
    857843838279679766814541009538837863609506800642251252051173929848960841284886\
    269456042419652850222106611863067442786220391949450471237137869609563643719172\
    874677646575739624138908658326459958133904780275900994657640789512694683983525\
    957098258226205224894077267194782684826014769909026401363944374553050682034962\
    524517493996514314298091906592509372216964615157098583874105978859597729754989\
    301617539284681382686838689427741559918559252459539594310499725246808459872736\
    446958486538367362226260991246080512438843904512441365497627807977156914359977\
    001296160894416948685558484063534220722258284886481584560285060168427394522674\
    676788952521385225499546667278239864565961163548862305774564980355936345681743\
    241125150760694794510965960940252288797108931456691368672287489405601015033086\
    179286809208747609178249385890097149096759852613655497818931297848216829989487\
    226588048575640142704775551323796414515237462343645428584447952658678210511413\
    547357395231134271661021359695362314429524849371871101457654035902799344037420\
    073105785390621983874478084784896833214457138687519435064302184531910484810053\
    706146806749192781911979399520614196634287544406437451237181921799983910159195\
    618146751426912397489409071864942319615679452080951465502252316038819301420937\
    621378559566389377870830390697920773467221825625996615014215030680384477345492\
    026054146659252014974428507325186660021324340881907104863317346496514539057962\
    685610055081066587969981635747363840525714591028970641401109712062804390397595\
    156771577004203378699360072305587631763594218731251471205329281918261861258673\
    215791984148488291644706095752706957220917567116722910981690915280173506712748\
    583222871835209353965725121083579151369882091444210067510334671103141267111369\
    908658516398315019701651511685171437657618351556508849099898599823873455283316\
    355076479185358932261854896321329330898570642046752590709154814165498594616371\
    802709819943099244889575712828905923233260972997120844335732654893823911932597\
    463667305836041428138830320382490375898524374417029132765618093773444030707469\
    211201913020330380197621101100449293215160842444859637669838952286847831235526\
    582131449576857262433441893039686426243410773226978028073189154411010446823252\
    716201052652272111660396665573092547110557853763466820653109896526918620564769\
    312570586356620185581007293606598764861179104533488503461136576867532494416680\
    396265797877185560845529654126654085306143444318586769751456614068007002378776\
    591344017127494704205622305389945613140711270004078547332699390814546646458807\
    972708266830634328587856983052358089330657574067954571637752542021149557615814\
    002501262285941302164715509792592309907965473761255176567513575178296664547791\
    745011299614890304639947132962107340437518957359614589019389713111790429782856\
    475032031986915140287080859904801094121472213179476477726224142548545403321571\
    853061422881375850430633217518297986622371721591607716692547487389866549494501\
    146540628433663937900397692656721463853067360965712091807638327166416274888800\
    786925602902284721040317211860820419000422966171196377921337575114959501566049\
    631862947265473642523081770367515906735023507283540567040386743513622224771589\
    150495309844489333096340878076932599397805419341447377441842631298608099888687\
    413260472156951623965864573021631598193195167353812974167729478672422924654366\
    800980676928238280689964004824354037014163149658979409243237896907069779422362\
    508221688957383798623001593776471651228935786015881617557829735233446042815126\
    272037343146531977774160319906655418763979293344195215413418994854447345673831\
    624993419131814809277771038638773431772075456545322077709212019051660962804909\
    263601975988281613323166636528619326686336062735676303544776280350450777235547\
    105859548702790814356240145171806246436267945612753181340783303362542327839449\
    753824372058353114771199260638133467768796959703098339130771098704085913374641\
    442822772634659470474587847787201927715280731767907707157213444730605700733492\
    436931138350493163128404251219256517980694113528013147013047816437885185290928\
    545201165839341965621349143415956258658655705526904965209858033850722426482939\
    728584783163057777560688876446248246857926039535277348030480290058760758251047\
    470916439613626760449256274204208320856611906254543372131535958450687724602901\
    618766795240616342522577195429162991930645537799140373404328752628889639958794\
    757291746426357455254079091451357111369410911939325191076020825202618798531887\
    705842972591677813149699009019211697173727847684726860849003377024242916513005\
    005168323364350389517029893922334517220138128069650117844087451960121228599371\
    623130171144484640903890644954440061986907548516026327505298349187407866808818\
    338510228334508504860825039302133219715518430635455007668282949304137765527939\
    751754613953984683393638304746119966538581538420568533862186725233402830871123\
    282789212507712629463229563989898935821167456270102183564622013496715188190973\
    038119800497340723961036854066431939509790190699639552453005450580685501956730\
    229219139339185680344903982059551002263535361920419947455385938102343955449597\
    783779023742161727111723643435439478221818528624085140066604433258885698670543\
    154706965747458550332323342107301545940516553790686627333799585115625784322988\
    273723198987571415957811196358330059408730681216028764962867446047746491599505\
    497374256269010490377819868359381465741268049256487985561453723478673303904688\
    383436346553794986419270563872931748723320837601123029911367938627089438799362\
    016295154133714248928307220126901475466847653576164773794675200490757155527819\
    653621323926406160136358155907422020203187277605277219005561484255518792530343\
    513984425322341576233610642506390497500865627109535919465897514131034822769306\
    247435363256916078154781811528436679570611086153315044521274739245449454236828\
    860613408414863776700961207151249140430272538607648236341433462351897576645216\
    413767969031495019108575984423919862916421939949072362346468441173940326591840\
    443780513338945257423995082965912285085558215725031071257012668302402929525220\
    118726767562204154205161841634847565169998116141010029960783869092916030288400\
    269104140792886215078424516709087000699282120660418371806535567252532567532861\
    291042487761825829765157959847035622262934860034158722980534989650226291748788\
    202734209222245339856264766914905562842503912757710284027998066365825488926488\
    025456610172967026640765590429099456815065265305371829412703369313785178609040\
    708667114965583434347693385781711386455873678123014587687126603489139095620099\
    393610310291616152881384379099042317473363948045759314931405297634757481193567\
    091101377517210080315590248530906692037671922033229094334676851422144773793937\
    517034436619910403375111735471918550464490263655128162288244625759163330391072\
    253837421821408835086573917715096828874782656995995744906617583441375223970968\
    340800535598491754173818839994469748676265516582765848358845314277568790029095\
    170283529716344562129640435231176006651012412006597558512761785838292041974844\
    236080071930457618932349229279650198751872127267507981255470958904556357921221\
    033346697499235630254947802490114195212382815309114079073860251522742995818072\
    471625916685451333123948049470791191532673430282441860414263639548000448002670\
    496248201792896476697583183271314251702969234889627668440323260927524960357996\
    469256504936818360900323809293459588970695365349406034021665443755890045632882\
    250545255640564482465151875471196218443965825337543885690941130315095261793780\
    029741207665147939425902989695946995565761218656196733786236256125216320862869\
    222103274889218654364802296780705765615144632046927906821207388377814233562823\
    608963208068222468012248261177185896381409183903673672220888321513755600372798\
    394004152970028783076670944474560134556417254370906979396122571429894671543578\
    468788614445812314593571984922528471605049221242470141214780573455105008019086\
    996033027634787081081754501193071412233908663938339529425786905076431006383519\
    834389341596131854347546495569781038293097164651438407007073604112373599843452\
    251610507027056235266012764848308407611830130527932054274628654036036745328651\
    057065874882256981579367897669742205750596834408697350201410206723585020072452\
    256326513410559240190274216248439140359989535394590944070469120914093870012645\
    600162374288021092764579310657922955249887275846101264836999892256959688159205\
    60010165525637568
  9. Henry Kiefer
    Henry Kiefer Guest
    Thanks Fred!
    If I looked for a crypt key I can use the bible ;-)
    - Henry
    | > Stupid answer:
    | Want e too?
  10. Henry Kiefer
    Henry Kiefer Guest
    I had a flight over all papers on this side. Never seen a short sequence and their counterpart in the spectrum.
    | details yourself.
    That is the point: I need at least a week doing the math work. Install Mathlab, learn it, etc.
    | The paper:
    Of interest BUT IEEE is closed source. If I can load it via their Xplore access system I can try to load it on the local
    university - not at home.
    Otherwise they can trash it if most of the world cannot there documents - useless! And useless things will go the dino way...
    I just need a short table book having the sequences.
    It is not for a fancy military project or Bin Laden's next secure mobile phone the IEEE trying to avoid ;-)
    regards -
    Henry
  11. Henry Kiefer
    Henry Kiefer Guest
    Here are some pictures and LTspice simulation files:
    www.ehydra.dyndns.info/en/HarmonicSuppression/
    Outputs are filtered by a simple 1-pole low-pass. Same values.
    You can see that sig(1) vs. sig(2) have approx. 10dB more harmonics for the first few harmonic orders.
    (533mVrms vs. 514mVrms)
    Interesting is that higher harmonics get more power and ground noise is reduced.
    Don't ask about circuit values. Here LTspice is just a number cruncher and nothing is a real component.
    Have fun -
    Henry
    | regards -
    | Henry
  12. Henry Kiefer
    Henry Kiefer Guest
    | Magic sinewaves could be replaced by a simple delta-sigma modulator,
    | no? That's easy to do in an FPGA.
    I'm not sure if I can follow you. ds-m? I thought this is a a/d and d/a tech thing.
    I use a lookup table in ROM and send it via SPI as a bit-stream. Just clock-synched DMA.
    See my link posting for the bit-stream.
    regards -
    Henry
  13. John  Larkin
    John Larkin Guest
    John
  14. Ian
    Ian Guest
    I believe John is suggesting implementing a digital only (no D/A or analog
    A/D)
    sigma-delta in an FPGA, and feeding it a sine wave in digits. The output
    would then be a string of bits that would provide your required bipolar
    signal in real time.
    If you pick your oversampling as an integer multiple of the sine period, you
    could do this as a math (or spice) simulation, and capture the output
    sequence
    for one complete cycle to store in a LUT.
    You can evaluate how well it does with an FFT.
    Regards
    Ian
  15. John  Larkin
    John Larkin Guest
    Right. A counter would scan a sine lookup table, producing, say,
    12-bit sines. A delta-sigma stage then decimates that to a 1-bit
    stream whose duty cycle tracks the sinewave. I think Xilinx has
    appnotes.
    We've done something like this to force a 12-bit dac to have 16-bit
    resolution.
    John
  16. Henry Kiefer
    Henry Kiefer Guest
    | appnotes.
    | resolution.
    But how will this suppress the lower harmonics? I think the sprectrum of your solution is nothing else than a digital signal
    spectrum: amplitude(n) = 1/n * f^n and n=2k-1
    - Henry
  17. John  Larkin
    John Larkin Guest
    Well, you'd have to read up on the delta-sigma math. But the summary
    is that the process "noise shapes" the output spectrum, shifting the
    noise energy (and distortions) up in the spectrum, where the high
    stuff is easily filtered out. That's how a 1-bit dac can make good
    audio, or how a cheap d-s adc can deliver 24 bit data.
    John
  18. John Larkin
    John Larkin Guest
    Oh, yeah, if you used d-s, you can stick a multiplier after the sine
    lookup table and get high-resolution amplitude control for free.
    John
  19. Henry Kiefer
    Henry Kiefer Guest
    | >John
    Interesting.
    I cannot go in my actual project very high in frequency.
    regards -
    Henry
  20. Henry Kiefer
    Henry Kiefer Guest
    Can you explain what the parameter m means?
    regards -
    Henry
    | On Sat, 31 Mar 2007 22:30:38 +0200, "Henry Kiefer" <>
    | >| Have a look at:
    | >| 1973.
    | details yourself.
    | The paper:
    | >Thanks again!
    | >- Henry
