Curious, can two identical LEDs with Vf of 3V (30mA) be powered
reliably in series from a 5V regulated supply without using a dropping
resistor? Or is this not enough margin for die differences, thermal
runaway, etc. This is at room temperature. Thanks.
From what you've said, I question whether they would turn on at all at 5V.
Is there a minimum specified for Vf?
The LED's whose datasheets I've examined show wide spread in the forward
voltage.
With LED's, you really need to use a current source to drive them. The
typical thing, as you seem to know, is to just put a resistor in series
with the LED. If there is very little headroom, as when driving a blue LED
from 5 Volts, you may need a better current source than a resistor to VCC.
One circuit I've seen is to put the LED in series with a voltage follower
driving a resistor. Like this: (Use courier or another constant-width font)
VCC
/ ____
\ R1 \ / LED
+-------------| Q1 (NPN)
\ R2 \_>
| \ R3
GND /
GND
The idea is that Q1 is a follower. You pick the voltage you want across
R3, and you choose R1 and R2 to set that voltage, keeping in mind that
there will be a drop of around 0.6 V from the base to emitter of Q1. You
also want to keep in mind that Q1 will have some base current, so R1 and
R2 should be chosen so that the base current won't throw off the voltage
divider by much. If possible, you should look over the datasheet for Q1
and see if you can estimate the Vbe drop more accurately than just 0.6 V.
So if Beta is 100, and you want 30 mA in the LED, then the base current
will be 300 uA. So you should choose R1 and R2 to satisfy this inequality:
VCC/(R1+R2) >= 300 uA * 10
In other words, the voltage divider current should be at least 10x the
base current.
Oh, R3 will probably be pretty small.
HTH
--Mac
