W
Watson A.Name - \Watt Sun, the Dark Remover\
I have a precision resistor that I use (among several others) to
calibrate my DMMs etc. It's 987.3 ohm, .01% with radial leads in a
black cylinder that's about 3/8" (9mm) by 1/2" (13mm). The date code
looks like it's from 1968, so my question is, how much would aging
change the resistance of a resistor like this, assuming it's over 30
years old. I don't know if it's wirewound, but almost all of the
precision resistors that I have from that long ago are obviously
wirewound because they're on a bobbin. The top of this cylinder looks
like the element was inserted and then epoxy was poured over it, level
with the top. So I'll assume that it's wirewound. Any ideas? Thanks.
@@F@r@o@m@@O@r@a@n@g@e@@C@o@u@n@t@y@,@@C@a@l@,@@w@h@e@r@e@@
###Got a Question about ELECTRONICS? Check HERE First:###
http://users.pandora.be/educypedia/electronics/databank.htm
My email address is whitelisted. *All* email sent to it
goes directly to the trash unless you add NOSPAM in the
Subject: line with other stuff. alondra101 <at> hotmail.com
Don't be ripped off by the big book dealers. Go to the URL
that will give you a choice and save you money(up to half).
http://www.everybookstore.com You'll be glad you did!
Just when you thought you had all this figured out, the gov't
changed it: http://physics.nist.gov/cuu/Units/binary.html
@@t@h@e@@a@f@f@l@u@e@n@t@@m@e@e@t@@t@h@e@@E@f@f@l@u@e@n@t@@
