W
Watson A.Name - Watt Sun, Dark Remover
I pulled some chokes out of an old defunct VCR board, and along with
those I pulled a dozen or so transistors. Some of those were C1740s
which are 2SC1740s, which come in a case that's smaller and more
squarish than the TO-92. But several of these transistors were in the
same package but marked with odd numbers. Like the following:
C114_
E S G
A114_
E S F
A124_
E S D
A144_
E S G
The underscore is really a line over the last letter of the bottom
line. The E seems to correspond with the emitter designation on the
board silkscreen. All of them are marked with a Q, such as Q901,
etc., on the board, so I don't think they are dual diodes in a
transistor package.
If those were 2SC and 2SA numbers, they would be so low that they
would probably be the old germanium transistors. Therefore I don't
think that any of these are 2SA114, etc. Does anyone know what the
transistors are? I have pictures! </Dr. Phlox> if needed. Thanks.
@@F@r@o@m@@O@r@a@n@g@e@@C@o@u@n@t@y@,@@C@a@l@,@@w@h@e@r@e@@
###Got a Question about ELECTRONICS? Check HERE First:###
http://users.pandora.be/educypedia/electronics/databank.htm
My email address is whitelisted. *All* email sent to it
goes directly to the trash unless you add NOSPAM in the
Subject: line with other stuff. alondra101 <at> hotmail.com
Don't be ripped off by the big book dealers. Go to the URL
that will give you a choice and save you money(up to half).
http://www.everybookstore.com You'll be glad you did!
Just when you thought you had all this figured out, the gov't
changed it: http://physics.nist.gov/cuu/Units/binary.html
@@t@h@e@@a@f@f@l@u@e@n@t@@m@e@e@t@@t@h@e@@E@f@f@l@u@e@n@t@@
C114_
E S G
A114_
E S F
A124_
E S D
A144_
E S G
transistor package.
