PWR bench SCR power supply
Discussion in 'Electronic Repair' started by grodgers, Oct 5, 2005.
  1. grodgers
    grodgers Guest
    Hi. i have a bench power supply made by PWR inc. wich has seem to stop
    existing.
    It seems that it was damaged by a line spike. I don't have any schematics
    but i do have a good knowledge of electronics. Anyone have working knowledge
    and/or any information of this unit or its manufacturer. It's a 40 vdc 200
    amp variable power supply (SCR on the primary side) and the manufacturer is
    PWR inc. 15305 Stony Creek Way Noblesville IN
    Thank-you
  2. sofie
    sofie Guest
    grodgers:
    First, with your "good working knowledge of electronics" you should open it
    up and perform some basic troubleshooting, component testing, and meter
    readings. If you are unable to diagnose the fault with that effort then you
    should post the exact symptoms with more words than "damaged"... and the
    results of your troubleshooting, component testing and meter readings.
    There are a lot of knowledgeable folks on this newsgroup that can give you
    repair suggestions but FIRST you have to post some better clues and more
    information.
