P
Peter
Is there a direct formula for calculating the voltage from a PWM circuit?
say I had a PWM chip controlling a FET with X volts feeding the FET, is
there a direct calculation?
I work better with real numbers and felt using real numbers would result in
people thinking I'm asking a homework problem, however, using whole numbers
would be easier.
Say 10 volts at the drain and 100kHz at the gate, what would I get out
(assuming there is a direct calculation).
Thanks in advance.
would be easier.
Thanks in advance.
