PWM that will work with a reversible power supply
Bobwhite
Jan 28, 2021
5
Jan 28, 2021
5
I am running a small 12 volt motor with a 12 volt, reversible, remote controlled power supply. I need to be able to adjust the speed of the motor. I have seen PWMs with a reversible switch, but that would not work for my application. Is there an off the shelf PWM that will work with reversible current ? All the ones I've seen say reversing the polarity will damage the PWM.
Bobwhite
Jan 28, 2021
5
Jan 28, 2021
5
Couldn't you put a potentiometer in the circuit to slow the motor speed? What would happen when the poles were reversed to the POT?
Bluejets
Oct 5, 2014
6,901
Oct 5, 2014
6,901
Pots are normally rated at around 1/4w, not suitable, and resistance inclusion also defeats the purpose of using pwm.
bertus
Nov 8, 2019
3,304
Nov 8, 2019
3,304
Hello,
Could you use a DC control voltage?
Then have a look at the attached article.
The control voltage can be in place of the potmeter.
At ca. 52 % Vcc the speed is max forward.
At ca. 33 % Vcc the speed is 0.
At ca. 5 % of Vcc the speed is max reverse.
Bertus
  • 3166_article.pdf
Bobwhite
Jan 28, 2021
5
Jan 28, 2021
5
Can I add the PWM before the power supply? Will the PWM effect the operation of the reversible, remote controlled power supply?
bertus
Nov 8, 2019
3,304
Nov 8, 2019
3,304
Hello,
In the given circuit IC1b, IC1c and IC1d will perform the PWM action.
It is controlled by the voltage coming from IC1a.
Bertus
bertus
Nov 8, 2019
3,304
Nov 8, 2019
3,304
Hello,
No, you can not apply PWM on the powersupply.
Bertus
