John O'Flaherty
I would like to use PWM in a control loop for power-saving purposes.
The controlled device needs to operate over a wide range of powers as
setpoint, so I was thinking of using 16-bit PWM from a microcontroller.
This would potentially have a range from 1/65000 to 1. It occurs to me
that the control will be grainier when operating at narrower duty
cycles. For example, if full power is at 50% duty cycle, and I want to
operate at full power/1000, the duty cycle control number will be
32000/1000 = 32. The minimum adjustment will be +/- 1, or 3% of that
level.
I have two questions about this-
1 Should the gain of the loop be adjusted to different levels depending
on the setpoint, i.e., should correcting signals be adjusted to a
percentage of the current level?
2 Is there a rule of thumb or other way to anticipate what dynamic
range can be had from that kind of control before it becomes too
grainy?
level.
grainy?
