PWM frequency for speed control of DC motor...
  • Thread starter they call me frenchy!
  • Start date
T
Howdy,
I have an application where I am designing a simple speed controller
for a 12VDC brush motor (pump). The motor draws approx 6 amps
continuous when running, depending on the load. I have the electronic
schematic all nailed down for driving the pump, but I need to set the
optimum PWM frequency for the motor that I am using. Can anyone refer
me to a nice text that discusses optimum PWM frequency choice for
optimum efficiency, etc. I assume that it is dependent on the motor
inductance, etc and I would like to research this matter fully. I've
found a few texts that touch on the topic, but none that delve into
it.
Any suggestions would be appreciated.
Thank you,
frenchy
P
Phil Allison
** Groper alert.
it.
** The PWM frequency that provides the most overall efficiency is the LOWEST
one that results in relatively smooth current flow in the motor - ie no
more than 10 % ripple at the PWM switching frequency.
High ripple percentages means the rms value of the motor current starts to
exceed the average value - the aim is to have them both the same. The rms
value is what generates waste heat ( I squared R losses) while the average
current value is proportional to motor torque & does the work.
As permanent magnet DC motors vary so much, this frequency can only be found
for sure with the motor on test with PWM drive and a scope monitoring the
current in the motor circuit.
Having said that, the frequency will likely be around 1 to 5 kHz .
........ Phil
C
colin
they call me frenchy! said:
Howdy,
it.
IMO adjust upwards until its no longer audible.
too high and you get switching losses,
too low and the current has a large AC component and it sings,
at some point the motor inductance will smooth out the current just enough.
Colin =^.^=
P
Phil Allison
"colin the fucking quarter wit "
** Even manic baboons have far more insightful opinions.
** So fucking whaaaaaaaat ????????????
The OP is after ** energy efficiency **
- you PIC poking CUNTHEAD !!
enough.
** For what exactly ?
Roller skates ?
........ Phil
