PWM frequency divider
Discussion in 'Electronic Design' started by [email protected], Apr 10, 2007.
  1. Guest
    Need simple circuit to divide the frequency of a 90 Hz PWM signal by 4
    while retaining the variable duty cycle.
  2. Tom Bruhns
    Tom Bruhns Guest
    Why? What do you want to do if the duty cycles go as, say, 10%, 20%,
    30%, 40%, 10%, 20%, 30%, 40%, (repeat ad infinitum)? What sort of
    resolution do you want?
    One way: divide the leading edge (assumed to be evenly spaced, with
    the trailing modulated) by 4. Integrate the "on" time for 4 input
    cycles. "Deintegrate" that value during the next output cycle to
    determine the "on" time for that cycle. Have two integrators that
    swap back and forth between the two tasks of integrating and
    "deintegrating". Easy enough to do in a 6-pin microprocessor, if the
    instruction cycle time of the uP is short enough for your required
    resolution. But there's a 4/90 second delay with this scheme.
  3. I've been thinking about something similar recently.
    You need a 2x D-types for a divide by four, 2x counters,
    2x R-S flipflops, some gating, and a clock (not less than
    10Khz for about 1% resolution on the output 22.5KHz PWM).
    <---T---><---T---><---T---><---T--->
    __ __ __ __ _
    90Hz | | | | | | | | |
    _____|T1|_____|T2|_____|T3|_____|T4|_____| 90Hz
    ________ ________ | _
    /2 | | | | | |
    _____| |________| |__|_____| /2
    _________________ _
    /4 | | | |
    ____/|\ |___________|____/|\ /4
    Set Set
    __ __ __ __ | _
    _____|T1 T2 T3 T4|_________________|_____| 22.5Hz
    |_____________________________| _
    _____| Counter1 gating signal |_____|
    Gate Counter1 to accumulate 10KHz clock pulses
    for the period T1+T2+T3+T4. At the end of T4,
    transfer the total count to Counter2, and Zero
    it The end of T4 is signalled by the 90Hz, /2,
    and /4 waveforms all being down.
    Use the Set output from /4 to set an R-S flipflop,
    whose output is the 22.5Hz.
    Also use the R-S output to Start the countdown of
    Counter2, clocked by the 10KHz, (and to reStart the
    Counter1 T1+T2+T3+T4 accumulation).
    When Counter2 reaches Zero, Reset the o/p R-S flipflop.
    The output duty cycle is then (T1+T2+T3+T4)/4*T.
    The sequence can either be done in hardware or a uP.
  4. Jim Thompson
    Jim Thompson Guest
