pwm for a boost converter
Re: this schematic:
http://www.cpemma.co.uk/555pwm.html
If I change C1 to 500 pF, would I get a 20 kHz PWM frequency?
Would any other modifications be necessary to achieve 20 kHz?
I'm trying to build a boost converter, and I'd like to use a variation
on this circuit to perform the switching.
Michael
C1 smaller (than shown), and the pot smaller (maybe 10k).
500pF is a little on the low side for a 555 but will still work. I think
20kHz is about right for that (or 0.005uF with a 10k pot).
I heartily recommend an UC3844 or similar chip for doing a boost converter.
The current protection will keep your transistor from exploding, a notable
advantage.
I was messing around with a BS boost circuit (two comparators and an op-amp,
plus the obvious hardware) just tonight and popped two power transistors.
:( Car batteries can sink a lot of current...
Tim
Ditto. Those 555 circuits are like using a crescent wrench instead of
a socket. Eh, maybe pliers instead of a socket.
T
Tim Williams
advantage.
Tim
R
Rich Grise
AKA "adjustable nut-fucker"
When some newbie would show up in our shop to ask to borrow a
crescent wrench, we'd ask, "Metric or Standard?" :)
Cheers!
Rich
H
Homer J Simpson
Left or right handed?
T
Tim Williams
Heh, I realize that those are useless distinctions which can actually
apply -- the only chiral part is the adjustment screw, while the wrench
length is measured in perhaps 8" or 200mm.
Now, a bucket of vacuum...
Tim
James Arthur
Re: this schematic:http://www.cpemma.co.uk/555pwm.html
Michael
That's not a very good general-purpose power supply, as others have
noted. Why not use one from my pal Bill Bowden?
http://ourworld.compuserve.com/homepages/Bill_Bowden/page4.htm#ps5.gif
Be sure and use a suitable (fast) rectifier, like a 1n5819 schottky,
or a fast-recovery type.
Best,
James Arthur
