pwm control of dc motor with chopper
Discussion in 'Sensors and Actuators' started by janakiramboss, Jan 26, 2014.
  1. janakiramboss
    janakiramboss
    Jan 26, 2014
    Greetings
    I am new to the forums and you like a little help with a project
    I would like help with the circuit details of pwm control of dc motor with choppers pls give me the circuit diagram with explanation of working . micontroller used to produce pwm signal was arudino .
    thanks lots
    janakiramboss
    MOD edited
  2. shumifan50
    shumifan50
    548
    56
    Jan 16, 2014
    The esiest way to do this is using an H_Bridge IC like the L293D that is controlled with a simple interface.
    Look at this link;
    H_Bridge motor driver IC
    A better microcontroller to use is a PIC with a PWM output to control speed by writing a simple value to a register (I don't know whether the arduino has a PWM output otherwise you will have to control the pulsing. The listed IC also support bi-directional motors.
