S
Silvar Beitel
Recently there were some comments in another thread about
microcontroller audio output techniques. (I can't find them now -
having to use Google Groups sucks - my otherwise reliable ISP
discontinued supporting a dedicated news server), and it leads me to
ponder a bit on what the best way to do this is.
On a prototype, using 8-bit audio (voice) data sampled at 8 kHz to
drive a PWM output, I just brute-forced the audio output path: A
multistage active LP filter (4 kHz corner freq) and a simple PA to
drive the earphones/speaker. I'd like to do something smarter/better/
cheaper on the next iteration.
Some options:
1) Multiply the PWM rate by N, reusing the data N times (or perhaps
interpolating), cut down on the active filtering required. However,
significantly upping the rate chews up processor cycles and increases
power. Enough to matter? I dunno yet.
2) Make a charge pump out of a tristateable output and internal
counters, drive it using differential data, and feed an external
integrator. The sampling frequency component at the output would be
significantly less compared to the PWM output and thus could result in
savings in the filtering circuitry.
3) Implement the "traditional" class-D LC filter output.
4) Just try to get the PWM frequency as high as the rest of the system
will allow and then drive the earphones/speaker directly, using the
speaker/headphones as part of the filter. Certainly cheap, but what
about emissions, especially out of probably non-shielded headphone
cords?
I haven't thought this all out, but am asking the group for input
because I'm sure some of you have already done this thinking for
me So, what have you done / would you do?
(P.S. The National LM48511 looks interesting. Have any of you used
it?)
Some options:
cords?
it?)
