PV cells and charge controller
Discussion in 'General Electronics Discussion' started by AUSER, Nov 12, 2012.
  1. AUSER
    AUSER
    Nov 12, 2012
    Hi all ,
    I'm currently working on a project to supply some loads throughout the PV cells .
    The output of the PVs is 10 V and 1.2 amps after connecting them in parallel .
    My question is , Do i need to use a charge controller to connect the PVs to a rechargeable
    battery ?
    As the batteries will be connected to the loads .
    If i need a charge controller can you please suggest some designs :D:D
    thanks a lot
    PS : i got the idea of a charge controller from this link http://www.wbdg.org/resources/bipv.php? r=office
  2. fromdawest
    fromdawest
    7
    Nov 17, 2012
    According to what I know, you MUST have a charge controller to be involved in your project . If not there is no way to protect battery from over charging . A charge controller circuit does charge the battery from the harvested energy ( solar energy > Dc electricity ), when the battery needs charging . If the battery is fully charge, then it blocks current flowing from PV cells to the battery to prevent over charging .
    First you need to connect the PV cells to directly to the charge controlling circuit, then the charge controller should be connected to the rechargeable battery . And then the loads can be connected to the battery directly .
    Refer this link
    http://www.instructables.com/answers/12-volt-Charge-controller-solar/
    or search google for ' charge controller circuits '
    Thanks ,
    Dileesha .
