peter.rabbit
- Mar 16, 2014
- 11
- Joined
- Mar 16, 2014
- Messages
- 11
I've built most of the circuit attached. It is, as titled a timed rocket igniter, and works well. I omitted the lower section of the circuit involving the third 555, as I didn't need the beeping buzzer.
I've been troubleshooting bouncing in the circuit, where the 2nd 555 would trigger on power-on, I solved this by actually following the schematic..... When I first breadboarded it I was short of some caps so made a bunch of substitutions, one of which was putting a 10uF cap at C10 instead of a 1uF - the circuit worked fine, but U2 would trigger on initial start-up.
I wonder now if this cap was damaged in an alligator clip incident during testing after stripboarding the circuit, that let the smoke out of one 555 and seriously injured the second....
My question though, is what cap C13 is there for? I'd left it out initially, and everything was working, and including it seems to make no difference....
Thanks for any advice anyone can offer....
