G
Guy Macon
I have been offered a small (about the size of a water
cooler) liquid nitrogen generator at an attractive
price. It generates four and a half liters per day,
using a gravity feed to keep a half liter dewar filled.
I want to pump the liquid nitrogen into a hole drilled
into the heatsinks of the CPU and GPU of a gaming PC
so I can overclock them farther than otherwise possible.
(This is for a a "just for fun" personal project, not
for work).
My question is how best to pump the liquid nitrogen.
In the past I have worked with big dewars and let them
self-pressurize with a relief valve on top and a feed
tube going to the bottom -- sort of like an aerosol
can. This doesn't look feasible in this case; the back
pressure seems like it will back up the gravity feed.
I think I need a small pump that can take the cold and
not add too much heat to the liquid nitrogen. Any ideas?
BTW, I have seven old 500 MHz. Pentium 3 systems that
are ready to be scrapped that I will be doing my
initial experiments on before deciding whether to
risk a more modern PC.
for work).
