kipster1203
- Jul 29, 2011
- 1
- Joined
- Jul 29, 2011
- Messages
- 1
I am using radio control to active a total of 3 different pumps.
This is a very old system that on the one side contains a control box with 14 push buttons (x7 START/ x7 STOP) which is then connected to the transmission box, and the other contains the receiver with another control box to manually turn on the pumps.
Pump 1 turns on without any problem. But then pump works at times and pump 3 now does not work at all.
Since pump 1 has no issues, I assume that I can rule out a transmission issue.
Could it be a problem with the push buttons?
