Pulse Width Modulation
Discussion in 'General Electronics Discussion' started by WaltP, Jan 20, 2018.
  1. WaltP
    WaltP
    10
    Jun 16, 2017
    I'm attempting to use a pulse width modulation control unit to operate windshield wipers on an old automobile. The little package unit I purchase works fine on the bench but because the PWM power input ground and the wiper motor ground cannot be separated on the car, the grounds are commoned and the unit will not control speed.
    Any advice on a way to get around this? Do I need to build an isolated 12DC to 12DC power supply? If so, can someone suggest a DC-DC converter that would handle the 3 amp load. I haven't had much luck.
    Thanks - Walt
  2. Minder
    Minder
    3,076
    657
    Apr 24, 2015
    There should be no reason why it would not work, post the schematic, why is the PWM unit Not being powered from the same supply as the wiper motor?
    M.
  3. WaltP
    WaltP
    10
    Jun 16, 2017
    I don't have a schematic of the PWM unit, but here's the hook up. On the bench, if the two grounds are jumped together the motor runs at full speed with no speed control.
  4. Minder
    Minder
    3,076
    657
    Apr 24, 2015
    There seems as though there is a conflict with the unit because the motor frame is at ground potential.
    You may have to see if you can isolate the -ve terminal on the motor from frame GND, or use a regular isolated motor,
    It may prove difficult to to do either.
    Unfortunately, generally auto wiper motors were not designed to operate with isolated -ve supply.
    The PWM unit is switching, (or trying to) switch the -ve side of the motor.
    Another alternative is modify to a P Mosfet output of the control.
    M.
  5. WaltP
    WaltP
    10
    Jun 16, 2017
    Isolating motor -ve would be a can of worms if at all possible and a regular motor is not an option due to originality. Do you see any issues with an isolated power supply feeding the PWM unit?
    Walt
  6. Minder
    Minder
    3,076
    657
    Apr 24, 2015
    The Mosfet in the PWM unit still has to be referenced to motor common. Which is also connected to auto 12v com.
    M.
  7. Bluejets
    Bluejets
    4,761
    999
    Oct 5, 2014
    Windscreen wipers are generally controlled via scr , the speed being delays between wipes rather than constant speed control of the motor.
  8. Kiwi
    Kiwi
    364
    89
    Jan 28, 2013
    What make and model of vehicle?
    What brand wiper motor?
    Single speed or two speed wiper motor?
    What are you actually trying to do???
  9. Minder
    Minder
    3,076
    657
    Apr 24, 2015
    The OP mentions an OLD automobile, so I would hazard a guess there is no solid state control back then, ;)
    I also assume from the OP that wiper control method is sought.
    Many of the really old models, either did it mechanically or even not at all.
    M.
  10. WaltP
    WaltP
    10
    Jun 16, 2017
    The vehicle is a 1957 Mercedes 190SL and the objective is speed control rather than intermitment operation. It's a two speed motor but generally the slow speed is to fast.
    I did have success with a dc/dc isolation power supply borrowed from another project ,see attached, but it's a kinda expensive route to take. It seems isolated dc/dc converters that handle 3 amps are pricey.
    Walt
  11. Minder
    Minder
    3,076
    657
    Apr 24, 2015
    Still doesn't make sense as posted, if the motor -ve is still connected to the motor frame.?
    Motor connections do not look right.
    M.
  12. WaltP
    WaltP
    10
    Jun 16, 2017
    No being as adept with electronic circuitry as most of you, it makes even less sense to me. Attached is a photo of bench testing, you'll note -ve is properly connected to the zinc die cast housing and +ve is connected to the slow speed terminal. The other three are high speed, maintain, and unused.
    If input and output negative on the PWM unit are jumpered, as would be the case with the unit mounted in the car, the PMW goes to 100% duty. An isolated dc/dc converter feeding the PWM eliminates that. pwm3.jpg
    Thanks - Walt
  13. Bluejets
    Bluejets
    4,761
    999
    Oct 5, 2014
    Yes, but I was referring to add-on devices.
    Earth will be for the park switch, not the motor wiring directly.
    Although there are many ways to achieve the 2 speed arrangement in original equipment, I have chased up a 2 brush motor diagram to save drawing out again.
    Yours may or may not be the same but it gives an inside into how perhaps your iso supply is operating.
    To the right are motor and park switch components.
    To the left is the "Off"..."Low"..."Hi"....speed selector switch.
    Cheers ..Jorgo
  14. BobK
    7,682
    1,688
    The problem is that the motor negative is connected to ground though the motor's houing.
    The PWM controller you are trying to use has to go between the ground of the motor and the circuit ground, which you cannot since the motor's ground is already connected to the chassis through it's housing.
    There are two ways to fix this.
    1. Isolate the motor ground from the housing. If the motor has a ground wire that just happens to be connected to the housing, detach that and then check for continuity between the housing and the wire. If there is no connectivity, then you can use the PWM unit by connecting to plus output to the newly separated wire, and the - output to the chassis ground.
    2. Get a PWM controller that switches the +12V instead of the ground wire. You may be able to do this by adding a P-channel MOSFET to the output of your existing PWM CONTROLLER. However, if you do that, the duty cycle will be reversed, i.e. it will be at full power when you turn the control all the way counter-clockwise, and at no power when you turn the control all the way clockwise. This you can fix by swapping the 2 outer connections to the potentiometer. If you want to go this route, we can try to talk you through it.
  15. WaltP
    WaltP
    10
    Jun 16, 2017
    The motor internals are packed so tightly that they're a bear to work on. I have a non-functional spare that I'll inspect for the possibility of isolating the ground.
    In the interim (and probably an easier solution) a rough sketch of a P-channel MOFET diagram would be greatly appreciated. No problem with switching the potentiometer around.
    Walt
  16. Bluejets
    Bluejets
    4,761
    999
    Oct 5, 2014
  17. Harald Kapp
    11,439
    2,627
    Why not? With the power to the pwm controller isolated via DC/DC converter it is possible to switch the '-' leg as it is isolated from chassis ground.
    This is imho a suitable alternative to building a high side switched pwm controller.
    Or follow @Bluejets ' link.
  18. WaltP
    WaltP
    10
    Jun 16, 2017
    Perfect - thanks.
    Walt
  19. WaltP
    WaltP
    10
    Jun 16, 2017
    Another question for the group. I've experimented with both an isolated power supply and building the circuit proveded by Jorgo , also attached below except with 1 p-Mosfet rather than two. I like this approach as it's been fun building the circuit and I'd like to make my first PCB but the voltage supplied to the motor is only 8.5 to 9 and with cold components, it's not enough to start the motor. I get the full 12v with the same power supply and Chinese PWM unit.
    If I procure addtional P-Mosfets, will the output voltage tend to increase?
    Thanks - Walt
  20. Bluejets
    Bluejets
    4,761
    999
    Oct 5, 2014
    With 2 output mosfets I would imagine it would be half the "on" resistance, so half the voltage drop on the mosfets.
    Just what this figure actually is depends on how hard the mosfets are turned on.
    Spec sheet says around 0.018 ohm.
