pullup AND pulldown on a chip input
Discussion in 'Electronic Design' started by samiam, Mar 27, 2007.
  1. samiam
    samiam Guest
    I just looked at a schematic I pulled off the net and I noticed that the
    Designer has a pullup resistor (to vcc) and a pulldown resistor (to
    ground) on the chip input.
    Exactly why is this done this way?
    I am used to seeing either one or the other.
    pullup for normally high
    or
    pulldown for normally low
    Forgive me, I am a software guy who takes an interest in such things. Thanks
  2. Jim Thompson
    Jim Thompson Guest
    It's called CYA... after the thing is built clip off the wrong one ;-)
    ...Jim Thompson
  3. "samiam"
    What kind of chip? If it was an op-amp, then the resistors act as a voltage
    divider to set the input bias. Not sure why everyone here is assuming it to
    be a digital input. :-?
  4. Jim Thompson
    Jim Thompson Guest
    Good point. I've devised several chips now where one pin gives a
    select-one-of-three function...
    Tie High = Mode A
    Tie Low = Mode B
    Float = Mode C
    ...Jim Thompson
  5. John Larkin
    John Larkin Guest
    This is a "Thevenin termination". Using two resistors lets you nail
    both the pullup voltage and the line termination impedance at any
    values you like. The VME bus, among many others, uses this sort of
    termination.
    Typical practice might be to have the high level be twice the nominal
    logic threshold or so, about 3 volts for VME, and the impedance
    whatever terminates best.
    John
  6. samiam
    samiam Guest
    What kind of chip?
    a buffer/quickswitch
    I think I am partly to blame for that. I mentioned that I am a software
    guy by trade. My interest in this is purely with digital circuits.
  7. 2.2k used to be my favorite pullup resistor -- red-red-red.
  8. Hawker
    Hawker Guest
    There are three main reasons why pull up and pull down resistors are
    used that I can think of off the top of my head. They are
    1) To put a pin in a default state while items power up. For example you
    may want a processor to bring a pin high and another pin low on start up
    but for a few ms while a chip initializes the outputs may be inputs or
    high Z and not assert this. It prevents pin contention/latch up and
    other issues. For example you may want an output enable pulled high
    (off) and a external power supply pulled down (off).
    2) Stiff (under 2.21k) Pull ups are used to increase speed transitions
    at times. This is especially true with opto isolators and OC outputs
    (see below)
    3) Pull ups are used for open collector outputs for the VCC reference
    since by nature open collector cutouts have no voltage on them.
    Hawker
  9. Hawker
    Hawker Guest
    Oh I misread the request, sorry. I see on the same pin. Yes most likely
    that is what it is. Although it could also be termination. Was this a
    clock line. The two add up to make an impedance. If this is the case
    the values are usually odd ball and pull up and down are different values.
    Also - depending on what it drives the default state they may have
    wanted was in the middle. Not many real world uses for this, but there
    are some.
    Hawker
  10. Rich Grise
    Rich Grise Guest
    [Top-Post Repaired]
    I used to use 2.4K routinely, since the time a bag of about 1,000 of them
    fell out of the sky onto my desk. ;-)
    Cheers!
    Rich
  11. Rich Grise
    Rich Grise Guest
    What are the resistor values, and what chips are on either end of the
    line?
    Rich
  12. Ban
    Ban Guest
    Yep, it is a termination for bus-lines used mostly on backplanes. The signal
    sees the parallel resistor value at the end of the line and doesn't get
    reflected. Whereas the driving current is only half of what it would be with
    a single resistor to gnd or Vcc.
    It makes only sense for CMOS, since these parts can source or sink the same
    current.
    A better way would be to create a middle voltage with a switching supply and
    terminate all lines with a single resistor to this. Now the dissipation is
    much lower, since we avoid the quiescent current in the dividers. There are
    ICs designed for this purpose.
    Some things have to be observed though. When no driver is active the middle
    voltage might cause excessive current in an activated input being in the
    linear region, so you have to stay above or below a bit. This will also give
    a defined output in this condition, all lines are low (or high), easily
    recognized by software.
  13. jasen
    jasen Guest
    eg MC140526 / SC41342 ?
    Bye.
    Jasen
  14. Jim Thompson
    Jim Thompson Guest
    Nope. The only standard product I've designed since 1970 have been
    ECL/PECL or LVDS. The parts with the three-way select were custom
    ASIC's, WiFi Repeater, GPS, etc. I've also used the scheme for
    production test... function not seen by ultimate user.
    ...Jim Thompson
