Pulling current through a FET while it's turning off
Discussion in 'Electronic Design' started by panfilero, Jun 19, 2013.
  1. panfilero
    panfilero Guest
    Hello,
    I'm trying to figure out how much current I can pull through a FET while its turning off... basically, how fast I have to turn it off if I have it hooked up to a constant current load so that the load doesn't kill my part while it goes through its resistance region... what information on the datasheet should I be looking at to figure this out?
    I'm guessing it's the power dissipation rating, but I'm not sure....
    Here's the FET I'm using
    http://www.st.com/web/en/resource/technical/document/datasheet/DM00048681.pdf
    much thanks!
  2. Joerg
    Joerg Guest
    You'll have to keep your eye on figure 2, the safe operating area or
    SOA. Make sure you never exceed the limits. For example, while at 200V
    Vds it can take 20A for 1mseec, but if it takes 10msec then only 7A.
    De nada :)
  3. Joerg
    Joerg Guest
    Oh, and that's for single pulse or "once in a blue moon". If such
    situations happen in rapid succession you need to also get into figure 3
    and avoid death local excessive local heating.
  4. Jamie
    Jamie Guest
    That's a nice part.
    to bad the gate cap is so high but I guess it would depend
    on the application at hand.
    It really depends on your application, I can see that being used in
    auto applications incase of load dumps etc.
    Personally my self, I wouldn't want a supper fast switching speed, with
    high voltage on drain side, the miller effects could prove to be
    interesting.
    Jamie
  5. Guest
    Guest Guest
    Hello,
    much thanks!
  6. josephkk
    josephkk Guest
    That is just not enough information. Where might the current
    alternatively go to and what is the compliance of the current source? Is
    there any energy transfer capacitors or inductors involved?
