A
Andrew Crook
1. I have used a voltage divider to add push buttons to a logic circuit.
2. I have also used capacitors with a voltage divider to make a auto reset
on power up on simple logic circuits.
However I have a device that acts as a switch, I need into act as a push
button i.e. a single pulse (high or low) when turned on (then opposite after
N secondes). Can I combine 1 and 2 in some way, have tried but don't get the
correct results.
regards
Andrew
correct results.
regards
Andrew
