Pull-down
Discussion in 'Electronic Design' started by James Cranfield, Aug 1, 2006.
  1. Hello,
    I sincerely apologise for the phenomenally newbie question but here goes....
    I have an ISD1730 chip which essentially plays a sound thru a speaker whenever one of the pins drops low, it has an internal pull up resistor.
    How can I use a non-physical switch to trip it? Basically I would like to have an Astable circuit trip it. How can I do this? Can I just put the output of an Astable onto it; or would I have to put a NOT gate in between so it is always high then goes low on the high pulse from the astable???
    Please help
    --------------= Posted using GrabIt =----------------
    ------= Binary Usenet downloading made easy =---------
    -= Get GrabIt for free from http://www.shemes.com/ =-
  2. Donald
    Donald Guest
    Need a little more information.
    If your npot using a "switch", what are you using ??
    An opto-isolator would work if I know what was controlling the opto.
    Help me, help you !
  3. mc
    mc Guest
    The latter, I think.
  4. John Fields
    John Fields Guest
    You could use an astable with complementary outputs and drive the
    1730 with the negative-true output, or if you wanted to use
    something like a 555/7555 you could do this: (View in Courier)
    IDS
    1730
    |_ |
    +---O|E |
    C +----+
    ASTABLE OUT>---[1KR]---B 2N3904
    E
    GND
