Public address system
Discussion in 'Electronic Design' started by Andrew Edge, Oct 7, 2009.
  1. JosephKK
    JosephKK Guest
    There are plenty of ways to do it digitally that do not involve the
    uncertainty if IP protocols. SMPTE has very good latency controlled
    digital systems. Total interoperability for compliant units.
  2. Joerg
    Joerg Guest
    Sure, but a church's budget is limited and we prefer to use more of the
    offerings to help with the food bank and stuff rather than buying
    expensive new gear. I think the old Yamaha power mixer has the potential
    to hang on for another five years. And it works :)
  3. krw
    krw Guest
    Usually hot ones, from what I hear. Popcorn too.
    It certainly is in the "mainstream" churches. There are a lot of
    congregational churches that are doing very well. Like newspapers,
    they have made their (death) bed.
    Sure, several varieties. ...and lotsa Presbyterian. Can't count 'em
    all. ;-) My wife goes to a large Babtist church here. Large enough
    to own half of the downtown area. There is a smaller Babtist church
    in back of our house (next road over). They're apparently doing quite
    well too; just built a new sanctuary. Now is the time to build, and
    they are.
  4. Les Cargill
    Les Cargill Guest
    True, but I don't see him needing timecode here? He's not synching
    two tape decks... right?
  5. Joerg
    Joerg Guest
    Ours is congregational (Lutheran) and slightly growing.
    Same here, we want to build a large two-story educational building plus
    a ballfield for the community around us. Problem is, while contractors
    are hungry fundraising is very difficult in this economy.
  6. krw
    krw Guest
    A lot of these churches have a lot of cash and likely more
    importantly, cash flow. OTOH, the church my wife went to in VT just
    had to decide to do something (i.e. build a gym) and the money
    appeared. When we left they had just decided to sell their current
    property (the town wouldn't let them build a new sanctuary on the
    other side of the road) and move to a more friendly town. ;-) They
    didn't seem to be worried about the megabux it was going to cost.
  7. Ross Herbert
    Ross Herbert Guest
    On Sun, 11 Oct 2009 01:38:30 -0400, "Michael A. Terrell"
    :Ross Herbert wrote:
    :> You post under the name of Andrew Edge yet you sign as Martin. Surely, if you
    :> really worked at MSW Systems http://mswsystems.com/home.htm you would have
    your
    :> own email address there. Incidentally, there is nothing on the MSW website
    that
    :> lists one of their services as "Public Address System Design". The stated
    main
    :> areas of services are "Systems & Networking, Web Design and Business
    :> Apllications" which says that they are merely engaged in IT design and
    support.
    :> This is a far cry from the engineering requirement required for a valid
    company
    :> experienced in PA system design. Of course, they could simply have failed to
    :> enter this function in their services lsting....
    :> I will be querying management at MSW as to your bonafides...
    :> It is plainly obvious to anyone who is experienced in electronics that you
    are
    :> not an electronics or PA engineer or anything like it. You say "you don't
    have
    :> as much time (as those of us who may be competent in the field) to give
    :> explanations", and that "there is more fun in life than debating on these
    :> issues".
    :> These two statements give you away as a fraudster and would NEVER be used by
    :> someone engaged in the PA design field. In fact, they are statements more
    likely
    :> to come from an uneducated juvenile out to cause trouble. Anyone who was
    :> seriously involved with the design of PA systems, as you claim to be, would
    have
    :> at the very least, a knowledge of electronics building blocks and how to
    select
    :> the appropriate items for the project at hand. You plainly don't possess this
    :> knowledge otherwise you would be pleased to describe in complex detail the
    :> environment you have to work with and the specific problems which this
    :> environment might present in coming to the best solution. That is the real
    :> reason why you can't be bothered to provide explanations.
    :> There are myriad problems in designing a PA system and there is no person on
    :> this earth who can supply you with the answers without ALL of the
    specification
    :> and details. It is a specialised field which does not really fit in with "IT
    :> Consulting".
    : His IP address resolves to Italy:
    :IP Information - 82.84.149.167
    :IP address: 82.84.149.167
    :Reverse DNS: ppp-82-84-149-167.cust-adsl.tiscali.it.
    :Reverse DNS authenticity: [Could be forged: hostname
    :ppp-82-84-149-167.cust-adsl.tiscali.it. does not exist]
    :ASN: 8612
    :ASN Name: TISCALI-IT (Tiscali Italia SpA.)
    :IP range connectivity: 1
    :Registrar (per ASN): RIPE
    :Country (per IP registrar): IT [Italy]
    :Country Currency: EUR [euros]
    :Country IP Range: 82.84.0.0 to 82.85.255.255
    :Country fraud profile: Normal
    :City (per outside source): Cagliari, Sardegna
    :Country (per outside source): IT [Italy]
    :private (internal) IP? No
    :IP address registrar: whois.ripe.net
    :Known Proxy? No
    :Link for WHOIS: 82.84.149.167
    : While mswsystems.com is in Tampa, Florida.
    :Registrant:
    : Mark Wykoff
    : 12506 Maverick Court
    : Tampa, FL 33626
    : US
    : Domain name: MSWSYSTEMS.COM
    : Administrative Contact:
    : Wykoff, Mark ****@mswsystems.com
    : Tampa, FL 33626
    : US
    : 7278045316
    : Technical Contact:
    : Tampa, FL 33626
    : US
    : 7278045316
    Thanks for the sender email address analysis Michael. This makes it even more
    evident that the OP is a fraudster in my book.
    The use of the Tampa based domain name along with the Google street view of the
    Maverick Court location strengthens my opinion that something fishy is going on.
  8. JumboBang
    JumboBang Guest
    There is a whole lot of crap in your email ... you sound like a 10
    year old which is probably what you are . Anyone can fake his
    location with a proxy if you know what that is.
    BTW your location is
    58.161.194.253 IP address location & more:
    IP address [?]: 58.161.194.253 [Whois] [Reverse IP]
    IP country code: AU
    IP address country: Australia
    IP address state: Western Australia
    IP address city: Perth
    IP address latitude: -31.9333
    IP address longitude: 115.8333
    ISP of this IP [?]: Telstra Internet
    Organization: Telstra Internet
    Host of this IP: [?]: CPE-58-161-194-253.nsw.bigpond.net.au [Whois]
    If you are angry with yourself just bang yr head against the wall and
    you'll do everybody a favor.
    JumboBang
  9. JumboBang
    JumboBang Guest
    IP country code: AU
    JumboBang
  10. Jumbo
    Jumbo Guest
    IP country code: AU
    JumboBang
  11. Ross Herbert
    Ross Herbert Guest
    :There is a whole lot of crap in your email ... you sound like a 10
    :year old which is probably what you are . Anyone can fake his
    :location with a proxy if you know what that is.
    :BTW your location is
    :58.161.194.253 IP address location & more:
    :IP address [?]: 58.161.194.253 [Whois] [Reverse IP]
    :IP country code: AU
    :IP address country: Australia
    :IP address state: Western Australia
    :IP address city: Perth
    :IP address latitude: -31.9333
    :IP address longitude: 115.8333
    :ISP of this IP [?]: Telstra Internet
    :Organization: Telstra Internet
    :Host of this IP: [?]: CPE-58-161-194-253.nsw.bigpond.net.au [Whois]
    :If you are angry with yourself just bang yr head against the wall and
    :you'll do everybody a favor.
    :JumboBang
    You're so smart you have to repeat yourself 3 times to get your message
    across.... and I am older than 10.
    I don't engage in fraudulent internet use such as the OP of this thread has
    done. I know anyone with the twisted aim of fooling others and hiding their
    identity can fake proxys but I haven't investigated how it is done because I
    don't need to know. The core of this issue is why does any smartarse feel the
    need to show their internet savvy and play childish games with such a useful
    tool as the internet. It is there for normal people who want to use it for its
    intended purpose, not juvenile gameplayers who love to jerk off and show how
    smart they are - while showing nothing more than how brainless they really are.
  12. JosephKK
    JosephKK Guest
    There is no requirement to buy fancy, what those standards get you is
    guaranteed interoperability.
