pspice vs ngspice
Discussion in 'CAD' started by David Logan, Mar 12, 2005.
  1. David Logan
    David Logan Guest
    Hello. I asked this question in an electronics mailing list that I am
    subscribed to, but I guess the moderator went on vacation or something.
    It was never sent out. So I will post my question here. It's a good
    forum anyway, since it deals with some sort of pspice issue (either an
    error on my part or an error in the software, I don't know which.)
    So, here is the question:
    Hey all! I am struggling my way through my introductory book. I have to
    spend 30 minutes on every one out of three problems figuring out where I
    went wrong :) But enough whining about it. I have a question about
    pspice for Windows (student version.)
    On this one in particular, I was having trouble getting the right
    answer, so I poked it into Linux/ngspice, and got an answer different
    than me, and different than the book. So I poked it into pspice for
    Windows (student version) and got different answers still.
    This is where I learned about current sources, arrows and +/- signs with
    regards to ngspice and pspice. After I fixed my circuit in ngspice, it
    gives me answers that correspond with the book.
    I just worked the problem by hand again, and got answers that also
    Thus, my multi-question mail has now dropped to one or two questions:
    1) Is pspice wrong? It must be, I think. But I'd like somebody to verify.
    2) If so, did I do something wrong? Or is there an error in their
    simulation code?
    Since it's a pain in the butt to post all of the details in an email, I
    have set up a web location to review:
    http://www.loganshouse.net/problem
    - The page with the original problem. It's problem 3.15
    - screen shot of the schematic, and the voltages/currents
    - screen shot of the schematic in ngspice
    The ngspice output files
  2. Hello David,
    you made an obvious mistake with the values of your resistors.
    A value has to be a number and not a mathematical expression.
    You tried with values like 1/3, 1/5 and 1/6.
    This can't work in SPICE. PSICE has treated all your resistors
    as 1 Ohm resistors.
    Why have you given NGSPICE a chance with with 0.333333, 0.2 and 0.166666?
    That's not fair. Give NGSPICE the same bad try with 1/3, 1/5 and 1/6.
    I assume you will get an error message.
    Be aware that the sign of the reported current through resistors
    may depend on the orientation. Resistors have also a "polarity"
    in some SPICE programs.
    See my explanantion above.
    Enter numbers like 0.333333, 0.2 and 0.166667 for the resistor values.
    Thanks for the good explanation and the screenshots. They really
    helped to understand what you have tried to simulate.
    You should try LTspice. It is similar in features to PSPICE, but it's
    totally free and unlimited regarding circuit size.
    LTSPICE can be downloaded from here:
    www.linear.com SwitcherCAD = LTspice
    The user group for LTspice:
    http://groups.yahoo.com/group/LTspice/
    Best Regards,
    Helmut
    ------------ LTSPICE schematic -------------
    Schematic for LTspice
    Copy the following text into a file named op_3_15.asc .
    Version 4
    SHEET 1 880 680
    WIRE 80 96 80 -32
    WIRE 80 160 80 96
    WIRE 80 304 80 240
    WIRE 144 96 80 96
    WIRE 256 -32 80 -32
    WIRE 288 96 224 96
    WIRE 288 160 288 96
    WIRE 288 304 80 304
    WIRE 288 304 288 240
    WIRE 288 336 288 304
    WIRE 352 96 288 96
    WIRE 496 -32 336 -32
    WIRE 496 96 432 96
    WIRE 496 96 496 -32
    WIRE 496 160 496 96
    WIRE 496 304 288 304
    WIRE 496 304 496 240
    FLAG 288 336 0
    SYMBOL res 64 144 R0
    SYMATTR InstName R1
    SYMATTR Value 0.166666667
    SYMBOL res 272 144 R0
    SYMATTR InstName R2
    SYMATTR Value 0.2
    SYMBOL current 496 240 R180
    WINDOW 0 -52 77 Left 0
    WINDOW 3 -47 6 Left 0
    SYMATTR InstName I1
    SYMATTR Value 4
    SYMBOL res 336 112 R270
    WINDOW 0 32 56 VTop 0
    WINDOW 3 0 56 VBottom 0
    SYMATTR InstName R3
    SYMATTR Value 0.3333333333
    SYMBOL voltage 128 96 R270
    WINDOW 3 -32 56 VBottom 0
    SYMATTR InstName V1
    SYMATTR Value 10
    SYMBOL current 256 -32 R270
    WINDOW 0 32 40 VTop 0
    WINDOW 3 -32 40 VBottom 0
    SYMATTR InstName I2
    SYMATTR Value 2
    TEXT 72 -112 Left 0 !.OP
  3. David Logan
    David Logan Guest
    Thanks for the info! The reason why I gave ngspice a chance and not
    pspice is quite simple. ngspice said "um, I don't know what these values
    are. Type something intelligent in." pspice was happy to take what I
    entered. Thus, I assumed pspice knew how to handle them.
    I'll keep that in mind for the future. Thanks!
    David Logan
  4. Jim Thompson
    Jim Thompson Guest
    [snip]
    PSpice treats "/" as additional or appended text, UNLESS written as
    {1/5}, then computation is done
    ...Jim Thompson
  5. Hello Jim,
    thanks for this tip. It works in LTspice as well.
    Expressions in curly braces {} are correctly evaluated in PSPICE and
    LTspice.
    Best Regards,
    Helmut
  6. Hi Helmut --
    [ . . . . snip!. . . .]
    : You should try LTspice. It is similar in features to PSPICE, but it's
    : totally free and unlimited regarding circuit size.
    : LTSPICE can be downloaded from here:
    : www.linear.com SwitcherCAD = LTspice
    : The user group for LTspice:
    : http://groups.yahoo.com/group/LTspice/
    I use and love LTSpice on my Windoze box at work, so I have no
    argument with your LTSpice advertisement. Howver, it does merit
    pointing out that ngspice is *also* totally free for download, and
    unlimited w.r.t. circuit size. Moreover, in contrast to LTSpice,
    ngspice is open-source, meaning that students can see the code, play
    with it, and modify it if they want.
    Finally, the OP apparently is running gEDA on Linux (look at his
    screen shots), and generating SPICE netlists with it for ngspice.
    That may explain why he is running ngspice, since it is Linux native.
    Yes, LTSpice does run on Linux under wine, but it's not a Linux
    native program.
    It's great to see the gEDA stuff being used by students!
    Stuart
  7. David Logan
    David Logan Guest
    That's absolutely right. I'm running Linux, which is why I'm using geda
    (which doesn't work so well), gschem, gnetlist and ngspice.
    I am also running pspice for windows, student version, because:
    1) Primary reason--my book uses pspice, and shows me how to use
    electronic modelling software via pspice.
    2) The linux software is seriously lacking in documentation, so I figure
    as I learn how to use pspice, I will simultaneously learn how to use the
    Linux tools.
    3) To compare pspice and ngspice for accuracy, to make sure that I get
    the same results from both. Since the book will have pspice examples and
    answers, this is possible.
    But my ultimate goal is be an electronics expert using Linux tools.
    David Logan
  8. : That's absolutely right. I'm running Linux, which is why I'm using geda
    : (which doesn't work so well), gschem, gnetlist and ngspice.
    It's good to see that you are using gEDA, bad to hear that it's not
    working so well.
    Since I'm one of the folks working on it, perhaps you could help us
    out a little bit. When you say "[it] doesn't work so well", please
    list two or three specific things which you think don't work well.
    Specific bug reports provide us with things to work on; therefore I'd
    be interested in hearing about the top two or three complaints you
    have about gEDA.
    [. . . . snip . . . .]
    : 2) The linux software is seriously lacking in documentation, so I figure
    : as I learn how to use pspice, I will simultaneously learn how to use the
    : Linux tools.
    There is some truth to this, but have you looked in your
    ${GEDA_INSTALL_DIR}/share/doc/geda-doc directory? There's lots of
    stuff there. Also, for gEDA/SPICE specific info you can look here:
    http://www.brorson.com/gEDA/SPICE/t1.html
    For ngspice commands, many people use this reference:
    http://newton.ex.ac.uk/teaching/CDHW/Electronics2/userguide/
    Finally, posting questions on the geda-user mailing list is a good
    way to get help if you have problems with the software. The mailing
    lists are here:
    http://www.geda.seul.org/mailinglist/index.html
    : But my ultimate goal is be an electronics expert using Linux tools.
    Welcome abord!
    Stuart
  9. David Logan
    David Logan Guest
    Thanks for all of that. I will review the links you gave. In all
    fairness, I suspect part of the problem I consider the documentation
    insufficient is because I don't yet know how to use electronics
    modelling software in general yet, and Linux software package
    documentation is usually lacking, especially for complicated software.
    I have a question with before I give my replies. The question is: When
    you say you are interested in hearing about gEDA, does that mean just
    gEDA, or does also mean gschem, gnetlist and ngspice?
    gEDA itself is crashing on me when I try to do certain things, so I quit
    using gEDA, and was just using the individual tools. If you are
    interested in specifics (regardless of the answer to the above
    question), show me the forum to post the bugs and the forum to post the
    whines, and I will be happy to do so.
    By the way, I have been a professional programmer for about 15 years,
    just so you know a bit of my background.
    David Logan
  10. : Thanks for all of that. I will review the links you gave. In all
    : fairness, I suspect part of the problem I consider the documentation
    : insufficient is because I don't yet know how to use electronics
    : modelling software in general yet, and Linux software package
    : documentation is usually lacking, especially for complicated software.
    : I have a question with before I give my replies. The question is: When
    : you say you are interested in hearing about gEDA, does that mean just
    : gEDA, or does also mean gschem, gnetlist and ngspice?
    Aaah, I see part of the problem already.
    gEDA = The gEDA project. This includes gschem, gnetlist, ngspice, and
    so on.
    geda = The gEDA project's project manager. An unfortunate choice for
    it's name, but we're saddled with it now. A better name might have
    been "gmanager" or something like that. Oh well.
    : gEDA itself is crashing on me when I try to do certain things, so I quit
    : using gEDA, and was just using the individual tools.
    You mean the project manager "geda" crashed on you, right? I don't
    use the project manager at all & instead use the individual tools.
    Geda (the project manager) is old, and hasn't been updated recently.
    It might have some bugs.
    The core tools "gschem", "gnetlist", and "gattrib" are under constant
    developement, as are several of the other smaller utilities. They
    tend to be bug-free, and very functional (except for gattrib, which
    awaits some features related to net and pin attributes).
    : If you are
    : interested in specifics (regardless of the answer to the above
    : question), show me the forum to post the bugs and the forum to post the
    : whines, and I will be happy to do so.
    Mailing lists:
    Bug reports:
    http://www.geda.seul.org/developer.html
    (click through to "jitterbug")
    : By the way, I have been a professional programmer for about 15 years,
    : just so you know a bit of my background.
    Cool! Any interest in hacking gEDA?
    Stuart
  11. David Logan
    David Logan Guest
    Yes, the project manager crashed. It is unfortunate that a cohesive
    environment doesn't exist like in pspice. One written with Qt would
    probably be good.
    I always have an interest. It's the time I don't have :)
    David Logan
