D
Don Pearce
That's true, but in SS, if components are joined end-to-end withoutI don't have a prob with the dots as far as indication of
connectivity is concerned, but I'd certainly want to turn them off
to print a schematic. I wouldn't want to have to use a separate CAD
program just to print a schem.
I also don't have a prob with the red lead indicating "not
connected", changing to blue or wire/component color when connected.
I can always move the component around to see if it's connected.
intervening wire, there is no rubber banding. Neither does the
attached component drag with the one you are moving - they simply
slide apart. I am not going to say this is a bug, and I'm not sure I
would do it any other way.
I think that is a result of the coarse grid - the v style of depictionSometimes in Capture, I've found that the part was connected wrong -
have to cut/paste or delete it and clean up a bunch of wire
segments. IOW segments end up under the part and sometimes moving
the part will cause an unconnected lead to connect to something
hidden under it. You have to watch out for that alert triangle that
indicates something's about to connect.
Since I'm talking about printing schems, something else about SS
annoys me, whether on screen or on paper. It's that limey looking
transistor symbol with the collector and emitter leads forming a "V"
at the base instead of being separated - the way I'm used to seeing
it. If there are other graphics in SS that annoy me, I've forgotten
them.
isn't normal in Limeyworld either.
Never tried LTSpice, but I have tried Capture and despite promisingOverall, I could live with SS if I had to. That LTSpice GUI is the
pits to get used to, which sucks because LT is a very useful CAD for
these group discussions.
myself to learn it and like it, I returned very gratefully to PSched.
And Kevin *has* conceeded to some of your points, thus upholding his
claim of excellent customer service.
This is very true.
d
Pearce Consulting
http://www.pearce.uk.com
