L
Larry Gipson
A long while ago when I used Pspice, I recall that it would only
accept curly braces for busses in subcircuit calls. Is this still
true?
So a 5 bit counter with a bus q[0:4], the call might look like this:
Xu1 q{0} q{1} q{2} q{3} q{4} counter
with similar notation on the subcircuit.
Is this still true or have they expanded Pspice now to accept square
backets and so forth?
I use (ECS, Synario) CohesionTools for schematic capture which allows
a range of options to represent bus structures and have always been
able to find something compatible with whatever simulator I'm using.
This is not true with LTspice as it apparently doesn't accept brackets
of any kind that I've found. The only option is to hand edit the
netlist replacing brackets with underscores - or deleting them
altogether. I suppose since the schematic capture in LTspice doesn't
do busses, there was no need to include them in the simulator.
Has there been an update I've missed? Has anyone else run into this?
Regards,
Larry
true?
Regards,
Larry
