B
Bob Penoyer
What is the best method for changing the names of project and other
files under Capture?
When I create a new project, I like to create a folder with an
appropriate name and put all of the new project's files in that
folder. I might create a project called ABC and save it in the folder.
As a result, a lot of the files created by Capture have ABC in their
names.
When I want to make major changes to the project, I copy the whole
folder to a new folder so, if things go wrong, I can fall back on the
previous version. After a while, as things are added and removed from
the design, the nature of the design might change. Or, I might want to
base a new project on the existing design. So I might want to change
the project's name to XYZ. But all of the other files still have ABC
in their names. Attempting to change the name has caused me a lot of
headaches. Is there a good way to go about such a name change?
names.
