PSpice boost converter output voltage problem
Discussion in 'Power Electronics' started by orcuns91, Aug 31, 2020.
  1. orcuns91
    orcuns91
    3
    Aug 31, 2020
    Hi everybody,
    I'm trying to evalute the performance of SiC mosfet in boost converter. After importing the model of the device to pspice, I simulated it in a basic boost converter circuit. However, the output voltage of the circuit is higher than the theoretically expected 800 volts. My values are f=50k Hz Duty=0,75 Vin=200 L=150uH C=10uF. Could you tell where the wrong is by looking at the pictures I uploaded? Thanks in advance
  2. WHONOES
    WHONOES
    1,190
    322
    May 20, 2017
    Tried it on my simulator and am getting about 740V. What sim are you using?
    orcuns91 likes this.
  3. orcuns91
    orcuns91
    3
    Aug 31, 2020
    Thanks for your answer. I'm using OrCAD capture pspice simulation. In my simulation , the input current is higher than expected. How can I limit the input current? Also, could there be a problem in driving the mosfet?
    The model of mosfet is https://www.rohm.com/products/sic-power-devices/sic-mosfet/sct3022klhr-product.
  4. WHONOES
    WHONOES
    1,190
    322
    May 20, 2017
    I use a simulator called SIMETRIX, have done for many years in my professional life and now in retirement. I think it is the best of the bunch.
    One thing to remember when doing this sort of simulation is that the inductor will need some dc resistance. I generally include it as a small value resistor either before or after the inductor.
    Another is that when using a voltage multiplying circuit such as yours, the input current will increase by the same ratio as the voltage multiplication factor plus a bit to account for losses. Thus if the input is 200V and the output is 800V which is a factor of X4 then with a load of 160R resulting in a current of 5A at the output then, the input current will be 20A.
    You don't get something for nothing.
    See attachments for my schematic and performance graphs
  5. orcuns91
    orcuns91
    3
    Aug 31, 2020
    Thank you very much for your advice. I will simulate again after reviewing the files.
