PSPICE A/D simulation problem
Discussion in 'Electronic Design' started by RsK, Apr 10, 2007.
  1. RsK
    RsK Guest
    Hi anyone can see the pspice file and please tell me how to remove the
    error it displays while simulation?
    regards,
    rizwan
    ..MODEL QBC337-25 NPN(
    + IS = 4.13E-14
    + NF = 0.9822
    + ISE = 3.534E-15
    + NE = 1.35
    + BF = 292.4
    + IKF = 0.9
    + VAF = 145.7
    + NR = 0.982
    + ISC = 1.957E-13
    + NC = 1.3
    + BR = 23.68
    + IKR = 0.1
    + VAR = 20
    + RB = 60
    + IRB = 0.0002
    + RBM = 8
    + RE = 0.1129
    + RC = 0.25
    + XTB = 0
    + EG = 1.11
    + XTI = 3
    + CJE = 3.799E-11
    + VJE = 0.6752
    + MJE = 0.3488
    + TF = 5.4E-10
    + XTF = 4
    + VTF = 4.448
    + ITF = 0.665
    + PTF = 90
    + CJC = 1.355E-11
    + VJC = 0.3523
    + MJC = 0.3831
    + XCJC = 0.455
    + TR = 3E-08
    + CJS = 0
    + VJS = 0.75
    + MJS = 0.333
    + FC = 0.643)
    *Resistors
    R1 2 4 56k
    R2 2 0 22k
    RB 2 3 180
    RC 4 5 5.1k
    RE 6 0 3.3k
    * Load
    RL 8 0 1k
    CL 5 8 10u
    *Capacitors
    C1 1 2 330n
    CC 3 5 470p
    CE 6 0 220u
    VCC 4 0 15
    ..AC DEC 10 10 100k
    ..PROBE
    ..END
  2. Jim Thompson
    Jim Thompson Guest
    Top posting to be as big an annoyance as possible ;-)
    (1) You show a model of an NPN. But there is no NPN in the netlist.
    (2) What does the error message say?
    ...Jim Thompson
  3. Hello rizwan,
    I don't know what PSPICE reports, but the error report from
    LTspice is crystal clear if you know SPICE.
    WARNING: Node 1 is floating.
    WARNING: Less than two connections to node 1. This node is used by C1.
    ---> one pin of C1 is not connected
    No AC stimulus found:
    Set the value of a current or voltage source to "AC 1."
    to make it behave as a signal generator for AC analysis.
    ---> An AC-analysis requires at least one voltage source with an "AC"
    definiton.
    This doesn't matter, but why do you have a transistor model when you don't
    use a transistor?
    Best regards,
    Helmut
