G
G. Morgan
If you're in an area with jurisdictions that are unclear, this database
is a good reference. The only problem is, there are no phone #'s!
"PSAP Registry:
In December 2003, the FCC began collecting data to build a registry of
public safety answering points (PSAPs). A primary PSAP is defined as a
PSAP to which 9-1-1 calls are routed directly from the 9-1-1 Control
Office, such as, a selective router or 9-1-1 tandem. A secondary PSAP is
defined as a PSAP to which 9-1-1 calls are transferred from a primary
PSAP. The PSAP database serves as a tool to aid the Commission in
evaluating the state of PSAP readiness and E9-1-1 deployment."
Link to .xls file of all PSAP's nationwide:
http://www.fcc.gov/pshs/docs/services/911-services/MasterPSAPRegistryV2.xls
(it's easy to cull the list down to just the area you serve (by State,
then Counties), then re-save the file as another name)
http://transition.fcc.gov/pshs/services/911-services/enhanced911/psapregistry.html
Related:
<http://www.securitysales.com/Channe...ram-Could-Cut-Houston-PSAP-s-Costs-by-2M.aspx>
"PSAP Registry:
Related:
