macgyver40
- Oct 19, 2018
- 2
- Joined
- Oct 19, 2018
- Messages
- 2
I am trying to use a proximity sensor with a Solid state relay to start and stop a 240v A/C 1.5hp motor with a ice cube relay timer. L1 is hot at all times. L2 is going through the proximity switch. The a problem is that the SS relay is allowing 3-4 volts through at all times, so the first time you energize it ,it will never stop the motor. Potentiometer to try to find a resistor to stop the voltage (if possible)? breakover diode (will it stop all voltage)? LED in line (A/C voltage)? incandescent bulb?
Any ideas to completely stop all voltage when the prox switch is made up? 120v A/C input
