Protel Autotrax and Win98
Discussion in 'CAD' started by Richard Hosking, Dec 10, 2003.
  1. I have a (licensed!) copy of Autotrax which is now a bit long in the tooth,
    but still works OK.
    It has run happily under W95 for years, but I want to put it on a newer
    computer with W98 - there sems to be problems with video drivers. The best I
    can get is low res CGA
    Anyone have later video drivers for this?
    Richard
  2. Alan
    Alan Guest
    Richard
    Have a look at:
    http://www.airborn.com.au/layout/easytrax.html
    HTH
    Alan
    Jenal Communications
    Manufacturers and Suppliers of HF Selcall
    P O Box 1108, Morley, WA, 6943
    Tel: +61 8 9370 5533 Fax +61 8 9370 5106
    Web Site: http://www.jenal.com
    e-mail: http://www.jenal.com/contact.php
  3. Many thanks for this
    It will regenerate the old program
    It looks like there is a better output option file as well for plotting to a
    laser printer.
    Richard
  4. I have managed to get the program running well under W98, but now I find the
    schematic libraries are reported as a "bad file format" and they wont load.
    This in spite of reloading the libraries from disk. Has anyone faced this
    problem? Was there a solution?
    Richard
  5. Chaos Master
    Chaos Master Guest
    *I think* it's caused by a FAT32 file system or long file names, or installing
    in a big hard drive. Or the files may be just corrupted.
  6. I reinstalled from the original disk - so they should not be corrupted. I
    have an 80GB drive - I guess that could be relevant. Filenames are the same
    as original - not longer than 8 characters. Any ideas on solutions?
    Richard
  7. Apollo
    Apollo Guest
    I run autotrax, and autotrax schematic, with libraries
    for both - there is definitely no problem with long file
    names, or having the programs on a large drive (etc).
    However, the libraries for protel autotrax and protel
    schematic are seperate, just like the PCB editor and
    schematic editor programs themselves - and if you try
    and load the library using the wrong program you will
    get the error you describe.
    I have a list of other stuff to watch out for! ...
    http://www.airborn.com.au/layout/autotbug.html
    Regards
    Steve
