P
Peter
Can someone tell me how you unroute a PCB?
Peter
Peter
Peter said:Can someone tell me how you unroute a PCB?
I know this is an old thread, so I don't really expect replies, but... doesSimon Peacock said:Just be careful you don't click on GND when you are doing unroute.. it can
take a while
Simon
Sorry Simon, I should have been more specific - I meant Protel ADVPCBSimon Peacock said:yep still works (in DXP 2004)
Simon
Johnny Boy said:Sorry Simon, I should have been more specific - I meant Protel ADVPCB
version 2.5, (Copyright 1991-1994)
Yep, I'm still using this relic. Works well for me. I mostly do 1-off boards
and when I do need a number, "IMP PC" in S.A., (Australia) can handle the
output files and they do a great job, with all of the usual features. I'm
too old to start learning again if I can possibly avoid it.
You're right about the vintage Simon, but it does work well under XP. Still,Simon Peacock said:unroute..
That's the old windows 3.11 version isn't it? not even win 98/xp
If it is, I can't remember. I have that version sitting around here
somewhere but Protel 99SE is far superior. It has exactly the same key
strokes but is considerably more robust. Unroutes weren't very reliable in
the 3.11 version as net names weren't as sticky (especially after updating
schematic to an existing PCB. The whole update process was considerably
upgraded between the win 3.11 stuff and Protel 3.0. Then again in Protel
99SE. Protel 99SE SP 6 is probably one of the best versions they have
released (after the 3.11 stuff). The newer DXP derivatives have more bells
but you need a high performance PC to run it. 99SE fly's with most modern
PC's and runs well under XP.
If you can afford it and can find it, I would defiantly recommend the
upgrade to 99SE. DXP is to unstable and they are adding features rather
than addressing some of the older problems.
Simon
Actually, one of my PCs is only a couple of months old, running XP Pro,Simon Peacock said:You wont regret an upgrade to 99SE... I wouldn't recommend going to DXP
unless you really want to replace your PC as well.
the trouble is getting a copy of 99SE these days. Its not supported but
occasionally you can find a copy. Ask on the DXP groups, you might find one
lurking around.
Simon
Johnny Boy said:Actually, one of my PCs is only a couple of months old, running XP Pro,
but I like using the old Win98 PC as my workhorse because it still allows
direct port access and I'm also using PIC programmer parallel port software
and other stuff, some is my own DIY software written with VC 6.0, that
relies on this.
Johnny said:Actually, one of my PCs is only a couple of months old, running XP Pro,
relies on this.
It's probably about time I upgraded everything, but the cost is
prohibitive.
... J (Steve)
