protection against vibration
Discussion in 'Electronic Design' started by veeresh, Jun 4, 2007.
  1. veeresh
    veeresh Guest
    On one of my PCBs i'm using a heavy IC. It is a 70pin gull wing
    package. And, the problem is that the pins are breaking near the IC
    package. I don't want to use RTV, as it's difficult to remove. What
    best I can do to protect this against vibration tests?
    Thanks and Regards,
    Veeresh
  2. If the board is close to a panel of some sort them you could use that
    thermally conductive matting stuff between the PCB and the panel that
    also acts as a vibration absorber.
    Got a link to the actual package?
    Vibration tests are done for a reason, if it's failing then you have
    trouble. Do you just want to a) pass the test (as you seem be to
    implying), or b) do you want to pass the test and make your product
    more reliable?
    Dave.
  3. Can you link to a package drawing?
    Best regards,
    Spehro Pefhany
  4. MooseFET
    MooseFET Guest
    The breaking is often caused by the PCB flexing. During the vibration
    test, the vibration may hit a resonant frequency for the PCB. Adding
    another attachment point ot the PCB can help.
    Placing a rubber foot such that the PCB bumps into it if it deflects,
    will often help to damp a resonance.
    Changing details of the mounting will often help. Basically, you want
    to push the resonant frequency up and increase losses. It matters
    less how you do this than that it is done.
  5. Tim Wescott
    Tim Wescott Guest
    Or going to a thicker PC, or attaching stiffeners to the PC -- One of
    these will be the least expensive for you, but it depends on your situation.
    Tim Wescott
    Wescott Design Services
    http://www.wescottdesign.com
    Posting from Google? See http://cfaj.freeshell.org/google/
    Do you need to implement control loops in software?
    "Applied Control Theory for Embedded Systems" gives you just what it says.
    See details at http://www.wescottdesign.com/actfes/actfes.html
  6. Tim Wescott
    Tim Wescott Guest
    I think I would want to make my product better, and pass vibration tests
    as a consequence, rather than being focused on passing the tests and
    damn what happens to my product in the field.
    Tim Wescott
  7. Marra
    Marra Guest
    Rubber mounts on the pcb should reduce it.
  8. John Larkin
    John Larkin Guest
    As others have mentioned, it's flex resonances of the board itself
    that are probably the problem. Boards will blur at resonance, and
    literally throw parts off. The board should be stiffened, damped, or
    vibration isolated.
    John
  9. veeresh
    veeresh Guest
    Hello Sir,
    Thanks for the kind response from all of you.
    It has passed the tests some times. But when tested for many times,
    the pins break. I want to make it rugged... exactly option (b) :)
    The PCB is housed in an enclosure with screws at every 5cm w.r.t each
    other. Please check the link below for package diagram.
    http://www.ddc-web.com/FileLibrary/Default.aspx?type=Datasheets&div=MIL-STD-1553
    please consider the data sheet of BU-61580(second one ). I'm using the
    gull wing package - page 44 of 46. I took this perticularly to save
    the space.
    Now, I've kept a sil pad below the device, super glue on four corners,
    and RTV on pins. Is this fine, or something better can be done?
    Regards,
    Veeresh
  10. veeresh
    veeresh Guest
    I think I can fill upto 1 inch to reach the top plate, using sil pad.
    ~Veeresh
  11. veeresh
    veeresh Guest
    Hello Sir,
    What can we use for this vibration isolation? Is it some kind of
    washers, and studs that we use to fix the board in the box?
    ~veeresh
  12. veeresh
    veeresh Guest
    please consider the link below
  13. veeresh
    veeresh Guest
  14. veeresh
    veeresh Guest
    please consider the link below. Sorry for inconvinience.
  15. veeresh
    veeresh Guest
  16. veeresh
    veeresh Guest
    US$ 1000 :)
  17. veeresh
    veeresh Guest
    actually they suggested putting glue on the pins, and all. But once
    glue is put, the maintainance will be diffiult
    Why don't you tell us
  18. John Larkin
    John Larkin Guest
    Google "vibration isolator". The classic vendor for this stuff is at
    lord.com.
    John
  19. Have you considered asking the manufacturer? Why don't you tell us
    how much it costs so Joerg can have a heart attack? Last part I used
    from that company was in the high four digits (USD).
    Best regards,
    Spehro Pefhany
  20. That's a lot of Sil-Pad dude, and it ain't cheap.
    There are much easier ways to solve your problem.
    Dave.
