Proscan TV Turns off immediately
Discussion in 'Electronic Repair' started by Scott Bright, Feb 22, 2004.
  1. Scott Bright
    Scott Bright Guest
    Model: PS36109
    Chassis: CTC197CH
    Problem: When I turn it on, it clicks on and off a few times then is
    quiet. Had it unplugged for 24 hours no change.
    I saw in one other post that it might be the "Hv Splitter Box". Can I
    order this and replace it myself?
    Thanks for any help.
    Scott Bright
  2. David
    David Guest
    The only way to get a handle on the real problem is to have proper
    troubleshooting performed on that chassis. This will include starting with
    hooking up the Chipper Check computer interface and software to the set to
    check the error codes, performed standard tv troubleshooting of the power
    supply and deflection circuits, and go from there.
    It will cost you far less to have a qualified technician with the proper
    equipment do a repair on the set than it will to throw parts after parts
    guesses at the tv set.
    David
  3. Jerry G.
    Jerry G. Guest
    The horizontal output transistor may also be shorted. Normally the flyback
    and HOT are changed together in many cases. If you change these parts, and
    do not troubleshoot to find the original cause of failure the new parts will
    be damaged upon restart of the set.
    After changing the flyback and HOT, finding the cause of failure, changing
    all the defective parts, he will then do the high voltage and power supply
    tests to see that the set is working safely.
    I would strongly recommend you call an experienced service centre to do this
    type of repair. There are also many safety issues when working in TV sets.
    This is especially true in the scan amplifiers, high voltage sections, CRT
    sections, and power supply.
    Greetings,
    Jerry Greenberg GLG Technologies GLG
    WebPage http://www.zoom-one.com
    Electronics http://www.zoom-one.com/electron.htm
    Model: PS36109
    Chassis: CTC197CH
    Scott Bright
  4. Jamie
    Jamie Guest
    could be.. (flyback)..your version of a Hv splitter box.
    while your at it you may want to change the HV output transistor.
    wwww.elctronix.com
    they have flybacks..
    you may need the number from the flyback.
  5. Jason D.
    Jason D. Guest
    On Sun, 22 Feb 2004 11:09:06 -0800, Jamie
    Snipped.
    Please, for safety reasons, please ask owner to bring it in for a
    estimate & repaired professionally. RCA authorized shop or one that
    is very famillar with RCA stuff is best.
    These chassis is good but it is best repaired by techs who knows it's
    uniqueness.
    Oh, PS36109 is med to high end 36" CRT TV not projector! CTC197 is
    CRT version and other chassis that looks same for projectors is
    CTC195. I'm surprised others didn't catch on that!
    Have two fit strong people to carry that tv around, suggest wear pair
    of heavy working gloves. The base is hard on fingers and very heavy
    because of flatter CRT than normal 36" CRT is normally is.
    Cheers,
    Wizard
