ProScan PS27123 CRT goes dead after 15 to 20 minutes
Discussion in 'Electronic Repair' started by kingphil, Dec 5, 2005.
  1. kingphil
    kingphil Guest
    This ProScan PS27123 is a great television, it worked great for years
    resolution and image quality are exceptional.
    Unfortunately after 9 years of loyal service, it started acting up.
    When I switch the set ON it starts normally, but after 15 to 2
    minutes the CRT goes black but sound still works. If I switch it OF
    and wait +/- 1 hr, I can re-open it and it will do it again
    Any guidance to what I should look into will be greatly appreciated.
    I want to keep this TV, but dont want to loose my shirt getting it t
    a sefvice center
    Thanks to all
  2. JANA
    JANA Guest
    From the age of the set, there are some components that have become thermo
    sensitive. With proper troubleshooting an experienced TV tech should be able
    to locate these parts, and replace them. The cost should not be too much.
    The main cost would be the labour.
    Take the set for an estimate to find out what they would charge to do the
    work. This is something an end user would not be able to do himself.
    JANA
    _____
    This ProScan PS27123 is a great television, it worked great for years,
    When I switch the set ON it starts normally, but after 15 to 20
    minutes the CRT goes black but sound still works. If I switch it OFF
    and wait +/- 1 hr, I can re-open it and it will do it again.
    I want to keep this TV, but dont want to loose my shirt getting it to
    a sefvice center.
    Thanks to all,
  3. Stuart
    Stuart Guest
    What's the chassis number?
  4. James Sweet
    James Sweet Guest
    Is it sensitive to vibration? Try thumping it lightly on the side before
    it acts up and see if that causes it to lose picture.
  5. RonKZ650
    RonKZ650 Guest
    It's a CTC169. I've had 2 in the last couple months that had this
    problem and it was a bad HV transformer in both cases. Check your 140v
    on the collector lead of the horiz output and see if it drops to zero
    when the picture disappears. Pretty strange, I've also had intermittent
    open flybacks on a couple of 187s recently.
  6. Guest
    I can tell you all... How ever you must be able to do... can you?
