Proper cleaning of an IC
Discussion in 'Electronic Basics' started by Kingcosmos, Jan 24, 2006.
  1. Kingcosmos
    Kingcosmos Guest
    Hello Group,
    I am interested if there is an industry standard on the simple cleaning
    of a dirty IC of general grime (dirt, skin oils, grease, etc). I am
    thinking acetone or isopropyl alcohol should be ok. I searched
    SemiconFarEast.com for articles but came up empty. Is there an
    industry standard for general cleaning of a chip? Any help would be
    appreciated.
  2. Guest
    soapy water works.
  3. Phil Allison
    Phil Allison Guest
    ** Never use soap or washing powder - they are alkaline ( caustic) and
    will corrode metal..
    Ordinary dishwashing liquid ( ie detergent) is fine - the rinse with warm
    water and hot air dry.
    ( Beware: Dishwasher liquid is also caustic. )
    ............ Phil
  4. KruSat
    KruSat Guest
    you had got it right buddy..........
    "isopropyl" is the best solution.But remember one good technique that i
    learnt about it...
    isopropyl evaporates quickly when poured directly on the board...
    instead what u do is take a very small piece of cloth or cotton bud(ear
    bud); dip in isopropyl and then clean it.... dont forget to close the
    bottle cap.... also i generally prefer to take small amount of
    isopropyl in a seperate small bottle so that u can dip the same old bud
    again and also prevent wastage....
    also it helps avoid accidents like dropping the bottle and damaging
    other things...
    Caution: Use gloves and face mask to be on a safer side...(its not
    that harmfull,but u must take precautions)
    Also if while using it u feel burning sensation in ur nose or eyes,
    stop its use immediately.
    I have learnt that some people are allergic to it but it is never
    noticed....(actully its Vapor causes it)
  5. --
    prove it.
    Member of DAV #85.
    Michael A. Terrell
    Central Florida
  6. Pooh Bear
    Pooh Bear Guest
    You *must* ??? !!!
    I've never needed to do that with isopropyl used in small quantities.
    Graham
  7. Rich Grise
    Rich Grise Guest
    Apparently KruSat has never heard of an "alcohol rub." ;-)
    Cheers!
    Rich
