Jamie M
I was wondering about plasmonic THz and higher frequencies, when they
propagate in copper the losses are extremely high due to the high
accelerations of electrons radiating losses. I saw some new info on
using metamaterials to "reduce electrons mass to near zero" using
alternate thin layers of material with positive and negative
permittivity:
http://www.upenn.edu/pennnews/news/...y-reduce-electrons-effective-mass-nearly-zero
I was wondering if this is a similar concept to a coax transmission
line for RF, in that it prevents losses/radiation until the antenna?
If a stripline transmission line is put on a PCB for THz
frequencies using the nanometer thick alternate layers from that paper
would that work to allow longer THz wires with low losses?
cheers,
Jamie
permittivity:
cheers,
Jamie
