Projection TV lens ?
Discussion in 'Electronic Repair' started by Henry Kolesnik, Dec 13, 2003.
  1. Do the lenses out of old projection TVs have any interesting use or value?
    tnx
    hank wd5jfr
  2. john
    john Guest
    I take then apart and use one of them for a Magnifier to use on PCB,s
    really works good looking for the ring joints.
    I even carry them on the truck for in home service.
    kip
    va3mm / ve3ckf / g0sle etc
  3. Mike
    Mike Guest
    also, if you get bored, you can build an LCD projector.
  4. SNELLN2
    SNELLN2 Guest
    Would someone explain to me how these can be used as magnifiers? Sounds
    interesting. I know the first surface mirror makes good reflectors for
    bouncing your ir around corners. Easy to cut and place where you need them.
  5. Bill Webb
    Bill Webb Guest
    Or fry ants :->
  6. Art
    Art Guest
    Yah!! I hear they are really good with chocolate syrup poured over them!!
    Ever try to fry a roach with one of those lens?? First you need to pin them
    down so the don't run of then hold the lens very still, focus that point of
    sunlight just behind the head!! Pop & presto!! Enjoy.
