Project using a strong 12 volt motor
Discussion in 'Sensors and Actuators' started by onlyblue, Feb 25, 2013.
  1. onlyblue
    onlyblue
    11
    Feb 2, 2013
    Hi
    I have a new project that I need to use a strong motor (12 volts) and I need to control the speed.
    I have been thinking for a car wiper motor because it has lots of torque. I will use as a power source a car battery.
    What is the best way to control the speed of such motor?
    Please give me your advice
  2. BobK
    7,682
    1,688
    PWM controller.
  3. CDRIVE
    4,960
    652
    May 8, 2012
  4. onlyblue
    onlyblue
    11
    Feb 2, 2013
    Thank you all for your replies, I had already search on ebay before I post, but I was not certain if the motor will work with most of the PWM I had found.
    My concern is that the car does not use a PWM to control the motors. This is the main reason I had asked. Also my dilemma is which is the right one since they have different specs.
    1 http://www.ebay.com/itm/12V-DC-5V-4...481?pt=LH_DefaultDomain_0&hash=item416d8743b9
    2 http://www.ebay.com/itm/12V-24V-48V...308&pid=100010&prg=1076&rk=5&sd=150901337994&
    3 http://www.ebay.com/itm/12V-36V-24v...308&pid=100010&prg=1076&rk=2&sd=150901337994&
    4 http://www.ebay.com/itm/DC-Motor-Sp...994?pt=LH_DefaultDomain_0&hash=item23226baf8a
    5 http://www.ebay.com/itm/DC-12V-24V-...043?pt=LH_DefaultDomain_0&hash=item3ccf47928b
    This is the one I had in mind (since I want the reverse function) I suppose I can do it with the right switch
    6 http://www.ebay.com/itm/5V-30V-5A-R...308&pid=100010&prg=1076&rk=1&sd=150901337994&
  5. CDRIVE
    4,960
    652
    May 8, 2012
    I would think that your motor draws less than 5A. Do you know what it draws?
    Chris
  6. onlyblue
    onlyblue
    11
    Feb 2, 2013
    No Chris, It only states 12 volts.
  7. Laplace
    Laplace
    1,252
    184
    Apr 4, 2010
    Wouldn't the current drawn by the motor vary with the load placed on the motor? The highest possible current would be the stall current. In the car what is the rating of the fuse on the circuit with the wiper motor?
  8. CDRIVE
    4,960
    652
    May 8, 2012
    That implies that the manufacturer shouldn't bother listing it on the data plate because it varies with the load. :)
    The ebay (10A) PWM model that I posted the link to should be fine because I doubt your motor will pull >10A.
    Chris
  9. (*steve*)
    25,497
    2,839
    Measure the DC resistance of the motor. That will allow you to estimate the stall current.
  10. CDRIVE
    4,960
    652
    May 8, 2012
    Good idea Steve but he'd be wise to not rely on merely probe/touch contact to measure it.
    Chris
  11. CocaCola
    CocaCola
    3,635
    5
    Apr 7, 2012
    A wiper motor isn't that big and the cheap PWM controllers should work fine, but if you go into a larger motor you look at 'scooter' speed controller an all in one package...
  12. onlyblue
    onlyblue
    11
    Feb 2, 2013
    I went back to the car junk and I have checked the fuse. it is 20Amps
  13. onlyblue
    onlyblue
    11
    Feb 2, 2013
    I measured the current (without load) and it was 2Amps. Then I had a installed a 5Amps fuse and I put a bit of load on the motor. The fuse burned, my multimeter not :)
    Thank you all for your answers. I will look for a smaller motor.
  14. CDRIVE
    4,960
    652
    May 8, 2012
    That's not the only load on that fuse. I would fully expect your wiper motor to pull about 5 to 7 Amps loaded or at start.
    Chris
