- Joined
- Nov 28, 2011
- Messages
- 8,393
Cool, so it does!
These look like they would work, assuming the magnetic characteristics are enough for your application. They are rated for 24VDC operation. The one with -030 in the part number has the lowest power consumption, 10W. At 24V the current will be:
I = P / V = 10 / 24 = 417 mA. The circuit I suggested should be able to supply it as shown. It will work from 24VDC. Use a decent sized battery - a battery of C cells at least, preferably D cells, or even larger.
Can you get those electromagnets in small quantities?
