Project at school
Discussion in 'Microcontrollers, Programming and IoT' started by PandaMan, Sep 13, 2011.
  1. PandaMan
    PandaMan
    17
    Sep 13, 2011
    Hello :). I'm new to these forums and new to PIC programming. We haven't been taught anything about PIC programming thus far at school, so I'd like some advice.
    I'm making a sort of novelty egg timer. It involves a wooden automata popping out of the base of the product when the time is up and starting a "Rube Goldberg" like chain reaction resulting in a bell being hit. I have several questions though.
    1. Can PIC chips time for long periods of time up to, say, an hour? When doing a mock program earlier I found you can't use "wait" for more than 65 seconds...?
    2. I want to use four buttons to set the time: +1 minute, -1 minute, +10 minutes and -10 minutes. How should I write the program in order for these buttons to add up the time?
    3. I would like to use an LCD display to show how much time has been entered. What extra programming will be involved?
    4. Taking all of this into account, what PIC chip would be best? I need two outputs for the motor but I don't know how many I need for the LCD display. I know I also need 4 inputs
    Thanks for any help.:D
    PandaMan
  2. (*steve*)
    25,480
    2,827
    Are you using a PIC, or a PICaxe?
    1) You can have longer waits by placing a wait of (say 60 seconds) inside a loop that executes 60 times. Bingo -- 1 hour delay.
    2) you need a counter for the number of minutes and at each press of a button increment or decrement it appropriately. Remember to debounce the button and not to decrement below zero or above the max count for the counter (or the max time you want the timer to time to)
    3) Lots. However if you use a PICaxe they have built in interfaces to some displays. If not, you may be able to find code that does it already. Interfaces can require between 2 and 8 I/O pins.
    4) You need to determine how many inputs and outputs you need, and how big your program is going to be. You also need a chip that has the appropriate devices on it (You don't need much I expect). There are about three bazillion different PIC chips, find something easily available with plenty of IO and memory. Internal clock is always good too. If you go PICaxe, there are fewer options so the choice becomes easier :)
    edit: Excess I/O and memory is so much better than I/O pins and memory you don't have.
  3. PandaMan
    PandaMan
    17
    Sep 13, 2011
    I was thinking of using a PICaxe 14M2, however if I want the LCD display it would probably be best to use a 20M2? That would definitely have enough memory for my program and I think there are enough pins.
    How many pins will this LCD need? http://www.picaxe.com/Hardware/Add-on-Modules/Budget-Serial-LCD-Module/
    What's involved in creating a counter? Is there a special function or do I use a variable? The way I was trying to do it before was to change a variable (say w0) by differing amounts depending on the button pressed, then when another is pressed to start the timer I used "sleep w0". The only thing I can think of about that is that I don't know how to add values onto a variable...?
    So if I used a 20M PICaxe, I would have 5 inputs, which would leave me with 13 outputs, right?
    PandaMan
  4. PandaMan
    PandaMan
    17
    Sep 13, 2011
    This is my code so far but I'm stuck. Could anyone help?
    Code:
    let b0 = 0
    main:
    	if pin1=1 then
    		let b0 = b0+1
    		endif
    	if pin2=1 then
    		let b0 = b0-1
    		endif
    	if pin3=1 then
    		let b0 = b0+10
    		endif
    	if pin4=1 then
    		let b0 = b0-10
    		endif
    	if pin0=0 then
    		goto main
    	elseif pin0=1 then
    		goto function
    		endif
    function:
    		wait 60
    And that's where I'm stuck. How do I make the "function" code loop?
    Is it something to do with the "do...loop" command?
  5. (*steve*)
    25,480
    2,827
    You need to do a lot more than that.
    You need to learn what debouncing means.
    If those various pins are your buttons, then you probably want to only count up when the button is pressed, not while the button is pressed.
    check out the "For" command. it lets you do things more than once...
    The PICaxe forum may be able to help you with interfacing to an LCD module.
  6. PandaMan
    PandaMan
    17
    Sep 13, 2011
    Ah ok. So to make the loop I need to do this?
    Code:
    function:
    		[B]for b0 = 0 to b0
    		wait 60
    		next[/B]
    		let b0 = 0
    		goto main
    I had thought about that problem with the buttons. I've read about debouncing. So how do I actually do it?
  7. (*steve*)
    25,480
    2,827
    That looks better, but consider, do you want to start from 0?
    Also, do you want to do something when the time expires?
    To debounce in software you read the button twice (or more) with a small delay between the reads. You ignore the state of the button if those reads are different.
    Once you have a debounced read of the button you need to compare the value to the last read. If it has changed you may need to take action (but maybe you don't). Lastly you remember this as the last read.
    If you get 2 readings of the button that are the same,
  8. PandaMan
    PandaMan
    17
    Sep 13, 2011
    Okay. I spent all lunch at school today working the programming out and from what I gather it is working perfectly. Yes, you're right I didn't want to start from 0.
    Yes, after the time expires there is a motor that will activate. I spoke to my teacher today and he said proper debouncing wouldn't be necessary, especially seeing as it's only a GCSE project.
    Here is the updated code. All I need now is the LCD programming.
    Code:
    let b0 = 0
    main:
    	if pin1=1 then
    		let b0 = b0+1
    		endif
    		pause 100
    	if pin2=1 then
    		let b0 = b0-1
    		endif
    		pause 100
    	if pin3=1 then
    		let b0 = b0+10
    		endif
    		pause 100
    	if pin4=1 then
    		let b0 = b0-10
    		endif
    		pause 100
    	if pin0=0 then
    		pause 100
    		goto main
    	elseif pin0=1 then
    		goto function
    		endif
    function:
    		if b0 = 0 then main
    		for b1 = 1 to b0
    		wait 1
    		next
    		high B.0
    		pause 700
    		low B.0
    		high B.1
    		pause 700
    		low B.1
    		let b0 = 0
    		goto main
  9. (*steve*)
    25,480
    2,827
    Yeah, that looks workable.
    It's not the best way to debounce switches, but it will probably work acceptably since it's not like you're going to manufacture this as a product :)
    I note you initialise b0 to 0, it is also good practice to initialise the states of the pins you're going to use (even if the default values are OK). It is also a good place to add comments, such as:
    b0 = 0 ' The number of seconds the timer will pause for.
    Your next task (should you decide to accept it) is to display the timer value on an LCD display.
  10. PandaMan
    PandaMan
    17
    Sep 13, 2011
    I've decided I'm going to go with an OLED display because I think they look cooler :p. And they have a lower power consumption, which would be wise if the timer could time for up to an hour (or even more).
    It would be simpler to use an OLED display that has a slave chip, because then I can just use the 'serout' command, right? And what else is involved with 'serout', as in other necessary code?
    PandaMan
  11. PandaMan
    PandaMan
    17
    Sep 13, 2011
    Here is my complete code. It has the OLED display coded in, as well as a beep on every button press and the timer makes the OLED display count down. Let me know what you think :)
    Code:
    init:
    	pause 500					;for OLED display to initialise
    	let b0 = 0				;makes sure the counter variable is at 0
    	serout B.2, N2400, (254,1)
    	serout B.2, N2400, (#b0)
    main:
    	if pin1=1 then
    		let b0 = b0+1
    		pause 30
    		high B.3
    		pause 50
    		low B.3
    		endif
    		pause 100
    	if pin2=1 then
    		let b0 = b0-1
    		pause 30
    		high B.3
    		pause 50
    		low B.3
    		endif
    		pause 100
    	if pin3=1 then
    		let b0 = b0+10
    		pause 30
    		high B.3
    		pause 50
    		low B.3
    		endif
    		pause 100
    	if pin4=1 then
    		let b0 = b0-10
    		pause 30
    		high B.3
    		pause 50
    		low B.3
    		endif
    		pause 100
    	if pin0=0 then
    		pause 100
    		goto main
    	elseif pin0=1 then
    		high B.3
    		pause 50
    		low B.3
    		goto function
    		endif
    function:
    		if b0 = 0 then main
    		for b1 = 1 to b0
    		wait 3
    		let b0 = b0-1
    		pause 30
    		next
    		serout B.2, N2400, (254,1)	;Clears the display
    		pause 30
    		serout B.2, N2400, ("Time's Up")
    		high B.0					;motor activates in one direction
    		pause 700
    		low B.0					;de-activate motor
    		wait 1					;wait for the chain reaction to start
    		high B.1					;activate motor in opposite direction
    		pause 700
    		low B.1					;deactivates motor
    		let b0 = 0				;resets b0
    		pause 30
    		goto main
  12. (*steve*)
    25,480
    2,827
    Does it work?
    If so, great!
    Good programming practice is to have the ENDIF lined up under the IF, and therfore the various pauses lined up under the IFs.
    Once you do that the fact that the various "pause 100" commands always execute will be obvious. You need to comment these and say why -- it's not obvious. Maybe the next person who works on this code won't understand (or perhaps the person who assesses your work won't either).
    It would also be good practice to note in your code (via comments) what the purpose and connection of all the variables and pins are.
    Even better,
    symbol SECPLUS pin1 ' pin 1 is the "add a second" pin
    symbol OLED B.2 ' B.2 is the serial connection to the OLED display.
    symbol SECONDS b0 ' b0 holds the number of seconds to delay
    and then you can code
    let SECONDS = 0
    if SECPLUS = 1 then
    let SECONDS = SECONDS + 1
    serout OLED, N2400, (254,1)
    ... etc
    As I've said before, our initialization section should also set the states of all the other pins you're using. Start off by making sure that the motor and buzzer are off! It's also good practice to set the directions of pins that are I/O pins. Even if you're using the default it serves to document what you're using. If someone ever tries to run the same code on a different PICaxe the same defaults may not apply.
    (I'm speaking from over 30 years of commercial experience here -- I'm not making this up)
  13. PandaMan
    PandaMan
    17
    Sep 13, 2011
    Ok that does seem logical. Thanks for the advice. I'll get on with that. :)
    nfortunately, this is all in theory so far.I've only just started the project and haven't got the PCB printed and I haven't bought the materials yet. It works in the simulation. :p
Similar Threads
Loading...
