Progress
Discussion in 'General Electronics Discussion' started by SparkyCal, Mar 24, 2020.
  1. SparkyCal
    SparkyCal
    843
    33
    Mar 11, 2020
    (*steve*) likes this.
  2. shrtrnd
    shrtrnd
    3,826
    527
    Jan 15, 2010
    Good work. Good luck on your next project.
    Cannonball likes this.
  3. bertus
    bertus Moderator
    2,506
    977
    Nov 8, 2019
  4. SparkyCal
    SparkyCal
    843
    33
    Mar 11, 2020
    Thank you
  5. Bluejets
    Bluejets
    5,616
    1,188
    Oct 5, 2014
    Good one.
    Now make one flash longer than the other.
  6. SparkyCal
    SparkyCal
    843
    33
    Mar 11, 2020
    I have not tried it, but I have a feeling that would involve changing the capacitor or resistor. Or maybe trying a variable resistor on one branch of the circuit.
  7. Bluejets
    Bluejets
    5,616
    1,188
    Oct 5, 2014
    Once again, good move, only if using a pot, think about what will happen if it is turned to one end in particular and how to avoid a problem.
  8. Harald Kapp
    12,455
    2,985
    In this article methods are shown how to:
    1. Vary the frequency of the oscillator without varying the duty cycle (mark/space ratio).
    2. Vary the duty cycle without varying the frequency.
    Of course both techniques can be combined to yield a variable frequency/variable duty cycle oscillator.
  9. SparkyCal
    SparkyCal
    843
    33
    Mar 11, 2020
    Thanks for the advice guys. My next adventure however, is to take a circuit that I successfully put together on a breadboard, and try to solder it on a normal board. Just to develop that skill.
    hevans1944 likes this.
  10. hevans1944
    hevans1944 Hop - AC8NS
    4,703
    2,203
    Jun 21, 2012
    @SparkyCal: no need to manufacture a "normal board" when you can buy pre-etched and drilled prototyping circuit boards consisting of parallel traces with holes drilled on a 0.1" spacing grid. These come in all sorts of sizes, some with gold-plated edge contact "fingers" for reliable connections to the external world. Not saying you shouldn't explore DIY etched circuit (printed circuit) boards, but if you learn the fundamentals of circuit board layout and design, there are Asian manufacturers who can make double-sided boards with plated-through holes really cheap. There are still a few American board shops still in business too, but proto-boards are very inexpensive and available off-the-shelf as an alternative. Going with surface mount devices (SMDs) is also the direction many "makers" are choosing. Parts are really inexpensive and very small, so special techniques are required to put everything together.
    Welcome to EP and please keep us posted on your progress. Remember, always, to have FUN with electronics while you learn. Nice pictures!
  11. bertus
    bertus Moderator
    2,506
    977
    Nov 8, 2019
    Hello,
    There are different ways to do the prototyping on PCB's.
    You have the prototyping boards or the manhattan style prototyping.
    I will attach some catalog pages for prototyping boards and for the manhattan style prototyping.
    Bertus
  12. SparkyCal
    SparkyCal
    843
    33
    Mar 11, 2020
    Thank-you. I had no idea thst there so many different types. There were several boards in electronic kits I purchased and I was just goi g to use those. They have round holes drilled in, with solder around the holes.
  13. bertus
    bertus Moderator
    2,506
    977
    Nov 8, 2019
