Programming PIC microcontroller
Discussion in 'Microcontrollers, Programming and IoT' started by bigone5500, Oct 19, 2015.
  1. bigone5500
    bigone5500
    712
    120
    Apr 9, 2014
    Do I need a PICKIT debugger to program a PIC? I am coming across these chips more often in my salvaging efforts and if I need one, it may be in my best interest to get one. My recent find is a PIC16F616.
  2. Gryd3
    Gryd3
    4,098
    875
    Jun 25, 2014
    A pickit will make your life easier, but it's not an absolute requirement...
    The reason it makes your life easier, is because pics actually require a 12V (I think) connection when you are programming them. If you can supply this in addition to the logic voltage levels, you can program a pic from another micro controller or another interface on a computer. (parallel for example)
    This is much harder than simply using a pickit though... I would recommend using a pickit... best of luck :)
    bigone5500 likes this.
  3. bigone5500
    bigone5500
    712
    120
    Apr 9, 2014
    Thanks.
  4. Colin Mitchell
    Colin Mitchell
    1,417
    313
    Aug 31, 2014
    The debugger will just frustrate you.
    You just need PICkit-2 to program the chips and MPASMWIN to take your program consisting of lines of assembly code and produce a .hex file
  5. Minder
    Minder
    3,066
    657
    Apr 24, 2015
    One advantage of the Pickit 2 over the 3 is if you do not need to program the latest and future Pic's is you can get the standalone .Hex program which also has the Signal generator/analyzer and USART debug feature which is very useful, I have found the ICD very useful for debugging.
    Also MPlab 8.92 is needed.
    M.
