programming AD75019
Discussion in 'General Electronics Discussion' started by midou999, Apr 15, 2012.
  1. midou999
    midou999
    Apr 15, 2012
    Hello,
    please , i want to program AD75019 , an analogue Cross point Switch from analogue devices 16x16, with FPGA, ad75019 have a serial interface, i'have to shift 256 bit into 256 bit shift register , once the register is full i apply a PCLK pulse to to transfer the register to latch (like it's mentionned in the datasheet) my problem is, that i can'T close or open any switch :(
    please , anyone could help, thanks in Advance
    this my configuration:
    VDD:11V
    VCC:5V
    VSS: 0V
    SCLK: 1MHZ
    this how i did the spi interface : a shift register of 256 bit with a state machine for controlling PCLK signal:
    -- spi_SM.vhd
    library ieee;
    use ieee.std_logic_1164.all;
    use ieee.std_logic_arith.all;
    use ieee.std_logic_signed.all;
    entity spi_SM is
    generic(N:integer :=256; C:integer :=9; D:integer :=4 );
    -- generic(C:integer :=9);
    port(
    clk :in std_logic;
    rst_n:in std_logic;
    data: in std_logic_vector (N-1 downto 0);
    SCLK: inout std_logic; --inout pour qu'il peut etre lu en process
    SIN :eek:ut std_logic;
    PCLK: out std_logic
    end spi_SM;
    architecture rtl of spi_SM is
    type States is (ACTIF, UPDATE, IDLE);
    signal state : States := ACTIF;
    signal EndSend : std_logic_vector(8 downto 0);
    signal t_rst_cnt_n : std_logic ;
    --Diviseur (pour generer la frequence d'horloge du port SPI(20Khz-5Mhz))
    component diviseur
    generic ( N : integer := 4 );
    port(
    clk : in std_logic ;
    rst_n : in std_logic ;
    clk_out : out std_logic
    end component;
    --Compteurnbit
    component Compteurnbit
    generic ( N : integer := 16 );
    port(
    rst_cnt_n : in std_logic ;
    OutCount : inout std_logic_vector(N-1 downto 0)
    end component;
    --Sregister
    component Sregister
    generic ( N : integer := 256 );
    port(
    clk : in std_logic;
    rst_n : in std_logic;
    S :in std_logic_vector (N-1 downto 0);-- durée de train d'impulsion
    Q : out std_logic
    end component;
    begin
    U0_diviseur : diviseur generic map(D) port map(clk, rst_n, SCLK); ---definir frequence de SPI (clk de base=20 Mhz)
    U0_Sregister : Sregister generic map(N) port map(SCLK,rst_n,data,SIN);
    U0_Compteurnbit : Compteurnbit generic map(C) port map(SCLK,t_rst_cnt_n,EndSend);-- counting 256 pulse to set EndSend
    send : process (SCLK,EndSend)
    begin
    if (rst_n='0') then
    t_rst_cnt_n<='0';
    else
    case state is
    when
    actif=>
    if (unsigned(EndSend) = 256) then -- opertation arithmetique donc convertit std_logic_vector en unsigned
    PCLK<='0';--0
    t_rst_cnt_n<='0';
    state<= UPDATE;
    else
    t_rst_cnt_n<='1';
    PCLK<='1';
    state<= ACTIF;
    end if;
    when UPDATE=>
    PCLK<='1';--0
    -- state<= actif ;
    state<= IDLE;
    when IDLE=>
    PCLK<='1';
    state<= IDLE;
    end case;
    end if;
    end process;
    end;
