SimonDwyer
- Dec 28, 2015
- 3
- Joined
- Dec 28, 2015
- Messages
- 3
Hello,
Im pretty amateur with this kinda thing as you'll learn, and not sure if this is the right place to post this, but we'll see how we go.
I'm wanting to power a 5v usb submersible pump using a rechargeable usb power bank (firstly: will this work?), then I want to wire a programmable timer into the cable to run the pump at certain intervals for a certain period. Ideally the timer would be powered by the same source, but if not possible then by AA batteries.
Is there an assembled 'product' that I can use for this? If so can someone point me in the right direction to source this?
So far my googling has failed, so thought I'd try this!
Simon
Simon
