Scotty Rienschield
- Sep 24, 2015
- 14
- Joined
- Sep 24, 2015
- Messages
- 14
I am looking for help in building this or for someone to contract it out to. What I am looking for is the ability to control output to a small dc motor via a programmable unit. Here is a breakdown of what I am looking for...
Use- Slot Car Drag Racing
Ability- In 1:1 drag racing, there are several controllers available to allow a piston driven engine to take off with limited power and gradually bring the power in so not to lose traction to the drive tires. This limiting could be done through timing, boost control (turbo application), or nitrous moderation. Slot car drag racing is a scale version of this...typically 1:24. We use several types of small DC motors with an input current from the track of 14-16v. We use a trigger type controller to take power from the power supply and send it to the track which powers the car. There are several controllers with resistance capabilities...but even the closest to what I am looking for only allows two power settings....basically a timer that the vehicle leaves under a resisted power and when the timer runs out, it allows a second power level (typically 100%). I am looking for a way to smooth this out with several adjustable levels...or even a time/resistance graph.
Functionability- This module, when powered by the incoming voltage (typically triggered by a microswitch)...would moderate the outgoing power to the track...increasing the voltage at a predetermined rate. The complete time of the car traveling down the track is typically between .700 and 1.800 seconds....so it would need to be programmable down to at least .01...but preferable .001 seconds.
I have been researching it for a while, but I have very limited knowledge of electronics and don't even know where to start. I will start with what I have here...and I am will be ready to answer whatever questions you guys have for me...
