Programmable Load
Discussion in 'Microcontrollers, Programming and IoT' started by Engine9005ering, Aug 2, 2018.
  1. Engine9005ering
    Engine9005ering
    5
    Aug 2, 2018
    Hi! Can someone explain to me how does programmable load operates? Like the circuit shown below
  2. (*steve*)
    25,500
    2,840
    Have you tried googling?
    If you don't understand what you find, post a link here mentioning what it is that you don't understand and we can try to explain it to you.
  3. Engine9005ering
    Engine9005ering
    5
    Aug 2, 2018
    Hi steve! Thanks for the info, do you have background about semiconductor test? I am studying how functional test works, (simple continuity test/diode test). See this link's page 29 https://www.soft-test.com/wp-content/uploads/2013/04/FunctionalTest.pdf , I understand what this link explains, but it doesn't explain how the programmable load operates. I tried to check it in google, I can't find any reference.
  4. (*steve*)
    25,500
    2,840
    Wikipedia has a page on programmable loads. For me it comes up as the first result after the paid advertising.
  5. Engine9005ering
    Engine9005ering
    5
    Aug 2, 2018
    Hi steve, yes the Wikipedia page defines the programmable load, but what I want is to know how the circuit (the one that I send earlier) operates.
  6. 73's de Edd
    73's de Edd
    3,223
    1,349
    Aug 21, 2015
    Sir Engine9005ering . . . . .
    With ALL of that info that he gave, the definitive info that you actually want is not even being there.
    All of that info that you reference to is aligned to implementation of testing circuitry utilizing an electronic load.
    The closest that you even approach to the actual load principle is on page 8-38 and that is totally devoid of the control circuitry levels into the variable pulse width driven power FET pair used as the absorptive load.
    Getting right on down to the circuitry "meat" of the principle, consult several of these references.
    https://www.google.com/search?newwi...j0i24k1j0i30k1j0i8i30k1.0.7W-YTKTlSiU#imgrc=_
    73's de Edd
    Richard9025 likes this.
  7. Engine9005ering
    Engine9005ering
    5
    Aug 2, 2018
    Thanks both!
