program pic16f877a for ds1307
Discussion in 'Microcontrollers, Programming and IoT' started by ElectronicsR, Apr 1, 2016.
  1. ElectronicsR
    ElectronicsR
    72
    Mar 23, 2016
    Hello,
    How to write code for ds1307??
  2. Sadlercomfort
    Sadlercomfort Ash
    424
    53
    Feb 9, 2013
    I would advise you to read the datasheet for the ds1307, if you haven't already: http://datasheets.maximintegrated.com/en/ds/DS1307.pdf
    The ds1307 uses the Synchronous Serial Port (SSP) Module. It operates in I²C mode and is connected too the PIC using the SDA and SCL pins.
    Assuming your using a PIC..
    The SSP Module has five registers for I²C mode, which need to be setup to interface correctly. An overview on how to do this can be found on pages 15-17 here: http://ww1.microchip.com/downloads/en/DeviceDoc/33023a.pdf
    If your PIC supports SSP, you can find more detailed information about each register in the datasheet.
    Reading things isn't fun, but it helps..
  3. ElectronicsR
    ElectronicsR
    72
    Mar 23, 2016
    I don't have CRO oscilloscope can i write code without it?
  4. ElectronicsR
    ElectronicsR
    72
    Mar 23, 2016
    how to earn complete data sheet
  5. Sadlercomfort
    Sadlercomfort Ash
    424
    53
    Feb 9, 2013
    You wont need an oscilloscope to help you write code.
    What do you mean by earning complete datasheet?
  6. ElectronicsR
    ElectronicsR
    72
    Mar 23, 2016
    ok,
    i will try to search it
    and how understand complete data sheet of pic or avr embedded system
  7. ElectronicsR
    ElectronicsR
    72
    Mar 23, 2016
    ok,
  8. Sadlercomfort
    Sadlercomfort Ash
    424
    53
    Feb 9, 2013
    You do not need to learn the entire datasheet, but just familiarize yourself with the basics and how the relevant registers tie in with each other. I would learn about the relevant registers first and which commands to use to set each register. I've listed the relevant ones below.
    The Synchronous Serial Port (SSP) module has five registers for I2C operation. They are:
    • SSP Control Register (SSPCON)
    • SSP Status Register (SSPSTAT)
    • Serial Receive/Transmit Buffer (SSPBUF)
    • SSP Shift Register (SSPSR) - Not directly accessible
    • SSP Address Register (SSPADD)
    Also, familiarize yourself with the SDA and SCL pins and how to set up the ports.
    Sorry its around page 237.
    ElectronicsR likes this.
  9. Amar Dhore
    Amar Dhore
    129
    12
    Dec 2, 2015
    As Sadlercomfort said, First you should know how the SPI communication works, then its easy to implement it in the Micro. You should go through some sample examples source code just to understand it.
    Sadlercomfort likes this.
  10. ElectronicsR
    ElectronicsR
    72
    Mar 23, 2016
    thanks man people for sorting help.
    i will buy cro then i will go forward
  11. ElectronicsR
    ElectronicsR
    72
    Mar 23, 2016
  12. ElectronicsR
    ElectronicsR
    72
    Mar 23, 2016
