Program counter
Discussion in 'Electronics Homework Help' started by vead, Dec 30, 2014.
  1. vead
    vead
    473
    14
    Nov 27, 2011
    Hello ,
    I need help , I want to make program counter for program memory
    program memory
    8 data line
    16 address line
    program counter
    16 input
    16 output
    clock signal
    output of program counter connected with input of program memory
    I need Idea how to make program counter ?
  2. vead
    vead
    473
    14
    Nov 27, 2011
    I have searched on internet. I saw this example. but I don't understand clearly.can some one give specif example to understand about PC
    Example: Intel IA32
    The Intel IA32 (better known by some as "x86") is a CISC architecture, which means that each instruction can be a
    different length. The Intel memory is byte-addressable. Each cycle the instruction decoder needs to determine the
    length of the instruction, in bytes, and it needs to output that value to the PC. The PC unit increments itself by the
    value received from the instruction decoder.
